What colour should 2t spark plug be ?
firefox
PostPosted: 17:26 - 19 Jan 2006    Post subject: What colour should 2t spark plug be ? Reply with quote
I have recently put a new ngk r spark plug into my 50cc 2t. i removed it to make sure it was still fine ect. when removed the cathod that is usally white is now tan. and round the top is black ? what does this mean thanks.
https://img30.imageshack.us/img30/2184/spark9ig.jpg
kb-zxr
PostPosted: 17:27 - 19 Jan 2006    Post subject: Reply with quote
A dark chocolate brown is the best i believe.
Anything white is bad, means its running lean. Brown should be OK as long as it isn't oilly or really carbony (is that a word?) Embarassed
firefox
PostPosted: 17:29 - 19 Jan 2006    Post subject: Reply with quote
well it is a brown colour as you can see from the pic. so this is fine ? cheers just that it will never start atm in the cold dont know why it has just started to happen, takes like 12 kicks to get it to fire.
kb-zxr
PostPosted: 17:31 - 19 Jan 2006    Post subject: Reply with quote
Yeah should be OK. If you got a Haynes manual for anything they usually have a guide in there somewhere with lots of pictures of spark plugs.
Kurt
bristol_sports_bikes
PostPosted: 18:40 - 19 Jan 2006    Post subject: Reply with quote
follow this liink ,it has pics and info about spark plugs and its colours
very good
>https://www.dansmc.com/spark_plugs/spark_plugs_catalog.html
honda vfr nc30 1991
Bec
PostPosted: 21:10 - 19 Jan 2006    Post subject: Reply with quote
I have looked in my manual to see where a 2t spark plug goes and I can't find it! Can someone tell me where it is please?
kb-zxr
PostPosted: 21:12 - 19 Jan 2006    Post subject: Reply with quote
Top of the cylinder above the piston I imagine Razz
Follow the HT lead to the engine. Take that cap off. That thing poking out is the plug. Should say in the handbook too.
Bec
PostPosted: 21:19 - 19 Jan 2006    Post subject: Reply with quote
Where is that on a mo-ped all I can find is my air filter !?
PostPosted: 21:25 - 19 Jan 2006    Post subject: Reply with quote
It is a wee bit oily from your picture. Better a bit oily than not oily enough.
Looks fine to me, They should be a biscuity brown colour, I tend to err on the dark side of brown (indicating a richer mixture), I don't really worry if there is some oil floating about there either providing it isn't interfering with the plugs functioning.
You will only get a real idea of how the engine is running by doing a 'plug chop' after riding the bike at full throttle for a while. Warm it up, go for a ride at full throttle, kill the engine, pull the clutch and come to a halt. Then check the plug, the colour of the electrode will then reflect how the bike is running at fully open throttle positions (which is where a 125 2t spends most of its life)
mchaggis
PostPosted: 21:28 - 19 Jan 2006    Post subject: Reply with quote
I assume there is a little hatch at the back of the 'footboard' at the front of the seat base? Normally it'd be where you put the petrol in. Above the petrol tank cap is another hatch. Lift that off and you should see the HT lead and plug cap under there. That is asuming that your moped is the same as most scooters I have encountered.
I must not be a troll...
Mmmm, Guinness
Skunkcap Freddie
PostPosted: 22:18 - 19 Jan 2006    Post subject: Reply with quote
that looks fine mate,
The last post was made 20 years, 288 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.42 - MySQL Queries: 13 - Page Size: 67.16 Kb
