| mr.z |
 mr.z World Chat Champion
 Posted: 00:14 - 21 Jan 2006 Post subject: FAO Stinkwheel.../Serious engine fiddleing.. |
Well, i just got back my cgs top end and.. it has a bent inlet valve (explaining a previous fueling problem)
COMPLETELY fudged cam followers and VERY shagged cam.. also a scored cylinder...
Does anyone know a cheap place to source these? i know skinkwheel has delt with small honda engines quite a bit..
How in the hell do you get the cam followers out? theres a sloted thing on the side, it spins and spins, i can see where spining it lines up a bolt hole.. but can't do anything else with it
Bit of a bummer to say the least.. i'm guessing a new engine would be a cheaper option but so much would need to be change with it then it would be better off a new bike.. when this was free it seems a shame  ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| Kickstart |
 Kickstart The Oracle
| stinkwheel |
 Posted: 03:13 - 21 Jan 2006 Post subject: |
Sorry pal. I have never worked on a push-rod engine before. Don't know the slightest thing about them. All the small hondas I have had were either 2-strokes or OHC.
Given the depth in the engine this involves, a replacement engine might be easier? Or it looks like you might be following the whole of chapter 2 in your haynes manual. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| mr.z |
 Posted: 03:45 - 21 Jan 2006 Post subject: |
Thanks for the replys,
Ah i was mistaken then, i was thinking c90?
Ive used david silvers a fair few times, i forgot they did pattern parts, so the may help.. (are pattlern valves generally ok? hmm..)
Ive highlighted the bit holding the cam followers in.. do they look familiar to anyone?
As for the current state of the engine, its guts are splayed for all to see, the bottom end is all closed up but the top end is access all areas!
One other thing, how much is a rebore? considering the head is out of the engine so all they would need to do is make the 'ole...
I fear a new engine might be the more sensible option, but that would mean replaceing ALL the electrics (replaced and soldered all the connectors on the loom allready ) and more or less the entire bike, so makes it barely worth it, this has been a learing process, i'd really love for this poor little abused engine to be helping me tear up the peak district this year
Again, thanks very much for the replys  ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| stinkwheel |
 Posted: 03:52 - 21 Jan 2006 Post subject: |
Sorry, still no wiser. I have worked on C90 engines (hell, ther is one in my bedroom stripped to the gearbox) but they are chain-driven overhead cams too. Only the REALLY early ones are pushrod.
I can see from the picture HOW it works, but I have never had those bits (or even similar bits) in my hand. I am a very visually orientated person I'm afraid. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Nath |
 Nath World Chat Champion
The last post was made 20 years, 278 days ago. Instead of replying here, would creating a new thread be more useful? |
