Gear lever getting stuck.
liquidiz3d
PostPosted: 15:31 - 21 Jan 2006    Post subject: Gear lever getting stuck. Reply with quote
Hello i have a Rieju RS2 Matrix and when i put my Rieju into gear 1 it seems to stick when it should spring back up. I am not happy about this as i have just got it out the garage after spending 600 pound on getting it fixed. Can anyone tell me where the spring is located or what i should do to try and fix it? Thanks for reading.
Daz
Guest
PostPosted: 17:43 - 21 Jan 2006    Post subject: Reply with quote
Never heard of one of those, I had to Google it - nice looking bit of kit Thumbs Up
If it's just come from the garage there's a chance they've just put the gearlever on in the wrong place and the linkage is catching on something - have a look and see if it's clear of the frame, cases or whatever. It might just need moving round on the splines.
liquidiz3d
PostPosted: 18:47 - 21 Jan 2006    Post subject: Gear lever getting stuck. Reply with quote
I have had a good look without removing fairing and it appears not to be catching on anything. The lever just does not come back up... but with a tap it springs back up the way it should. I will take it back to the garage on monday but if there is anything i could try to have a look at here at home i would. Thanks for the help hope someone can help me or point me in the right direction.
Daz
simon1221
PostPosted: 19:05 - 21 Jan 2006    Post subject: Reply with quote
Take it back to the garage and get them to do it properly, unless of course it was doing it before then?
liquidiz3d
PostPosted: 19:13 - 21 Jan 2006    Post subject: Gear lever getting stuck. Reply with quote
It was doing it before then yes, but only every so often when i put ever so slightly to much pressure on. Now it gets stuck every single time.
Daz
Guest
PostPosted: 19:56 - 21 Jan 2006    Post subject: Reply with quote
Maybe just the pivot (on the footrest?) needs a clean and re-grease.
liquidiz3d
PostPosted: 20:07 - 21 Jan 2006    Post subject: Gear lever getting stuck. Reply with quote
Cleaned it and put wd40 on .. still no luck thanks anyway.
Daz
Cog Head
PostPosted: 18:19 - 22 Jan 2006    Post subject: Reply with quote
Bump
Rieju RS2 50cc MATRIX Race Replica - Cagiva Mito 125 - VFR400 NC30
LukeVFR: Cog Head is a Karma whore Shifty
McGee: Hence I smell like a gimp
Teaman
PostPosted: 18:22 - 22 Jan 2006    Post subject: Reply with quote
possible that teh spring on your gear selector forks is damaged, not returning properly, is there lots of play in the selector when the bikes off,
There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them.
judderman3000
PostPosted: 19:16 - 22 Jan 2006    Post subject: Reply with quote
similar sort of question here, new bike when riding (messing) around on waiting for my b'day is reluctant to come out of first gear into neutral, im not thick the bike is stationary just wondering if anybody had any ideas, cheers
Judd - Hornet 600 (restricted) Micron Can, Belly Pan, Custom rear end, Single seat cowl, need to sort front end out e.g. headlights and USD forks...
Ichy
PostPosted: 19:40 - 22 Jan 2006    Post subject: Reply with quote
Possibly clutch cable needs adjusting?
MarkyPancake
PostPosted: 13:03 - 23 Jan 2006    Post subject: Reply with quote
I had a problem with my ZX-6R not going into gear, so I phoned the dealer and spoke to service, explained the problem and they suggested it could be a build up of dirt around the pivot point and to bring it in for them to have a look. An hour later with no charge and it was changing gear better than ever.
I don't know if yours might be a similar dirt problem.
fuzz
PostPosted: 13:12 - 23 Jan 2006    Post subject: Reply with quote
My SV certainly was. Take the lever off completely and regrease the whole thing. The bushes can trap dirt in them and cause too much friction for the spring to return the lever quick enough.
As for not going into neutral, almost certainly adjusting the clutch cable freeplay will solve it. Happened all the time on my NSR.
liquidiz3d
PostPosted: 13:36 - 23 Jan 2006    Post subject: gear lever Reply with quote
I took the gear lever apart and it is deffinately happening deeper into the bike as the problem still seems to happen when the gear lever is off and i just push the bar that goes into the pivot which holds the lever. I will just have to take it back to the garage although my clutch lever is quite loose... ill go and try to adjust that before i ring the garage. Thanks for all the replys
Daz
liquidiz3d
PostPosted: 14:31 - 23 Jan 2006    Post subject: Gear Lever Reply with quote
Ok i adjusted my clutch cable and that hasn't done anything but i noticed my oil light is flashing!? dont suppose that has anything to do with the problem? Thanks
Daz
The last post was made 20 years, 264 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.18 - MySQL Queries: 13 - Page Size: 80.19 Kb
