** Braking system **
AcIdBuRnZ
PostPosted: 02:00 - 22 Jan 2006    Post subject: ** Braking system ** Reply with quote
Hi,
OK. Time to get these new calipers fitted Thumbs Up Smile
I need to completely drain the system, so does anyone have any tips/advice on the best method to do this?
Also, any advice on how to fill a system from empty?
Many thanks,
Mark
mr.z
PostPosted: 02:29 - 22 Jan 2006    Post subject: Reply with quote
Get yourself a bleed hose, most car places do them, its a nonreturn valve of sorts, just a tube that only lets the fluid out and not back in..
Fit it to the caliper nipple, looesn the nip, pump the lever while filling, then fulid starts coming out then the fluid is all the way though the system Thumbs Up (you can empty it the same way, just dont put fluid in)
+Make sure to use copper slip on the back of the pads, slideing pins, and a very small ammount on the bleed nipple threds, even better get some stainless steel ones and do the same Thumbs Up
After your done use soemthing to hold the brake lever down overnight, this will make all the air in the system flow to the top, cable tie is good for this..
White Noise
Mr Dudwee
PostPosted: 09:01 - 22 Jan 2006    Post subject: Reply with quote
loads of info here (only one post up! Rolling Eyes Very Happy )
https://www.bikechatforums.com/viewtopic.php?t=33116
WN
AcIdBuRnZ
PostPosted: 13:15 - 22 Jan 2006    Post subject: Reply with quote
Cheers guys Thumbs Up
I'm OK with brakes/bleeding etc, just wasn't sure on how to completely empty/refill the system that's all!
Have some karma Karma
The last post was made 20 years, 272 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 43 Kb
