A few things about 2001 SV650S
kenny
PostPosted: 14:20 - 20 Jan 2006    Post subject: A few things about 2001 SV650S Reply with quote
any info on these:
iridium spark plugs, are cr8eix the correct ones to use.
the standard jet sizes i think the last owner rejetted it up because it had a aftermarket exhaust on it then removed it and replaced the with the standard system when they sold it so now its lumpy on the tick over.
Thanks,
KeNNy
KeNNy 100cc peugot speedfight 125cc Honda NSR125R 650cc suzuki SV650R 125cc suzuki GZ125 600cc yamaha YZF-R6
AcIdBuRnZ
PostPosted: 02:03 - 22 Jan 2006    Post subject: Reply with quote
RTFM Thumbs Up Wink
Ichy
PostPosted: 15:04 - 22 Jan 2006    Post subject: Reply with quote
cr8eix is the correct plug although cr9eix is slightly harder and MAY be better for the summer.
Don 't know standard sizes but I found this on the net at https://www.geocities.com/catpoopman/sv650_rejet.html
Jetting Info:
Pilots: 17.5
Main Jets: 137.5-140 (for stock exhaust)
140-145 (with aftermarket exhaust)
Needle: 2 shims under clip
Air/fuel screws: 2-3 turns (2.5 seems good for most)
Float: make even to leanest float. (if you even check it)
Jack Roe's multiple dyno runs showed an aftermarket full exhaust and stock filter worked best with: 140 mains, 17,5 pilot, 2-1/2 turns and 2 shims. Read the whole article HERE.
My current setup: desnorkled, full race exhaust 152.5 mains, 17.5 pilot, 2-1/2 turns, 2 shims, and a drilled slide hole.
Another good setup is desnorkeled, full exhaust 152.5 mains, 17.5 pilot, 2 1/2 turns, 2 shims.
Your setup could be different depending on type of exhaust, air filter, altitude and other mods. Trust your butt but stay close to the recomendations you see here.
fuzz
PostPosted: 23:33 - 22 Jan 2006    Post subject: Reply with quote
Here's the standard jet sizes (UK):
Pilot 17.5
Main 137.5
Pilot screw 2.5 turns out from full in
Float height 7mm
Fuel level 17mm
E-clip should be on second groove, with only the spacer underneath
You must also realise that the information given on the above link is for a Californian model SV, and therefore the jetting/needle position will probably need to be different for UK.
Some people also talk about using a slightly larger main jet on the front carb as the front cyclinder block is a slightly lower temperature than the rear. Whether this is a good idea or not, I don't know, but a 140 front/137.5 rear is not uncommon.
The last post was made 20 years, 264 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 2.35 - MySQL Queries: 13 - Page Size: 41.99 Kb
