| veeeffarr |
 veeeffarr Super Spammer
| stinkwheel |
 Posted: 13:23 - 23 Jan 2006 Post subject: |
Sounds like fuel starvation to me. Start at the tap and work down giving everything a clean and blow through.
Another thing that can cause poor starting is the tappets opening up but the lack of throttle response suggests a fuelling problem to me ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| veeeffarr |
| stinkwheel |
 Posted: 14:17 - 23 Jan 2006 Post subject: |
Well, yeah. If the air filter is badly choked, this would fix it.
Give the filter foam a good wash out then when they are still a bit damp, put a little oil on them. Now give them a good squeeze, you will see a mess of oil and water emulsion drip out (looks milky). Now leave them to air dry, applying the oil when they are damp spreads it evenly and thinly rather than in 'dollops'.
At a minimum, check the fuel tap/filter isn't blocked by pulling the hose off the tap and switching it on (with a suitable receptacle held under it). You want a steady stream of fuel to be coming out.
If you have one of the older type CGs your fuel tap will have a sediment bowl (which I think you described), take this off and have a look for any water droplets (which sink to the bottom) and any bits of crap, that is certainly simple enough. Have a look at the bit immediately above the sediment bowl, some bikes have a circular gauze screen filter here. Gently lever it out and give it a rinse through.
If the bowl is stiff DON'T use a spanner on the hex nut on the bottom of it, they can twist apart really easily. Use a big pair of pliers with padded jaws on the outside of the bowl itself (don't squeeze too hard). Mind you they SHOULD just be finger tight. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| bidman |
 bidman Crazy Courier
 Posted: 15:44 - 23 Jan 2006 Post subject: |
Also make sure your putting the choke on the right way and not flooding the engine down is off choke and up is on choke, Dan ____________________ Don't ride it, RAG IT!! |
| veeeffarr |
| danzai66 |
 danzai66 Scooby Slapper
| veeeffarr |
| Mark_petty |
 Mark_petty Brolly Dolly
 Posted: 19:58 - 23 Jan 2006 Post subject: |
atm i have to use full choke then after 30 seconds I turn it off and leave it for a few minutes and it seems to be ok. ____________________ [Rides: Suzuki GSF600sx]
[CBT: Passed] [Theory: Passed] [DAS: Passed] |
| veeeffarr |
| veeeffarr |
 Posted: 21:09 - 23 Jan 2006 Post subject: |
Update:
Got my air filter out...
Looks totally fine to me but TOTALLY stinks of petrol, so Ive washed it in fairy liquid and it's drying as we speak... It's two foam cylinders wrapped around a metal one, I've cleaned them all.
Checked spark plug, here's a picture of it, looks ok but the electrode is white?
I can't get the fuel line off of my tap, there's a clip on it that's fiddly as fuck.
The throttle rubber grip keeps slipping on the white plastic tube it clips on to... I don't have anything I can think of to stick it down... Anyone know of a bodge?
The throttle is a bit stick as well, I have some spray lubricant: I think it's this one: https://www.vueltausa.com/vuelta2/images/tools/TF2_sm.jpg
Would that do? I've used it before and its sticking after about a day? More permanent solution?
There's also something that looks like a giant green bogy stuck on my filter... ew...
Pics: |
| veeeffarr |
| finpos |
 finpos World Chat Champion
 Posted: 21:53 - 23 Jan 2006 Post subject: |
Hi Toby,
If it's not been starting, you'll have blown lot of fuel the wrong way through the carb, which explains the smell and the snot.
Green snot is probably emuslified petrol, i.e. you've had some water in the tank at some point. So possibly, that is causing you some grief. see Stinkwheel's fine advice. Alternately, if it's ok now, you might have run it all out.
With respect to you lines not lining up, remember the first rule - if it's not broke, don't fix it. It's unlikely it's spontaniously mis-aligned itself, and it was running fine before, wasn't it?
Your twist grip - to fix it properly, you really need to find out where the interference is. You'll probably have to strip down all the individual components to do this.
But getting your grip on should be easy. just spiral insulating tape around the white plastic part until the rubber won't slide on any more. Then squirt washing up liquid on it, push on the rubber and leave overnight to dry.
And, finally, in this weather, i wouldn't be expecting to give the bike any throttle at all until it had warmed up for a minute or so.
finpos. |
| veeeffarr |
| veeeffarr |
| veeeffarr |
| veeeffarr |
The last post was made 20 years, 257 days ago. Instead of replying here, would creating a new thread be more useful? |
