| Bullet |
 Bullet Trackday Trickster
| BFG |
 BFG Brolly Dolly
| Bullet |
 Posted: 15:12 - 24 Jan 2006 Post subject: |
we did consider fuel or air starvation as the most likely thing after changine the plugs, but it all looks clear, plugs not wet but did smell of petrol air box and filter look to be fine, as did the carbs when we had them off the bike, there didnt seem to be anything wrong with them, but we gave them a good clean while they were off anyway just incase... ____________________ nonstop unicorns vomiting sunshine pills into a rainbow toilet
past: ZXR750 J1, K1 & H1, GPX600R, Yamaha Radian. present: ZXR750 J2, SP-1, CB350 |
| BFG |
 BFG Brolly Dolly
| ancientd |
 ancientd Renault 5 Driver
| finpos |
 finpos World Chat Champion
 Posted: 18:17 - 24 Jan 2006 Post subject: |
Sounds like reducing the load on the bike's battery helps, so I'd try starting it off a good (i.e. not that one you threw in the back of the shed 3 years ago) car battery first.
Then worry about the head gasket
finpos. |
| Bullet |
 Posted: 02:28 - 25 Jan 2006 Post subject: |
didnt try it without the airbox fitted, but did try it without the backplate/filter in so effectivly not there, same result, for the hot starting trouble it had was it actually struggled to turn over the engine, would fire up right away when given a bump start. battery load doeant seem to be a problem at the moment, will spin over the engine more than happily, just no hint of a desire to start, tried jumping it when the battery eventually went flat after poking various things!, and even tried bump starting it down a big hill thinking it might give it more of a kick, that just resulted in the hard work of pushing the bugger home again! ____________________ nonstop unicorns vomiting sunshine pills into a rainbow toilet
The last post was made 20 years, 254 days ago. Instead of replying here, would creating a new thread be more useful? |
