Complete loss of power... :(
Cog Head
PostPosted: 00:12 - 26 Jan 2006    Post subject: Complete loss of power... :( Reply with quote
riding around tonight with a m8, going about 60 or so, felt the bike randomly start to slow (down a gear) keeps bogging down (i put £5 in my tank about 10 mins erlier) keep going down gears until i am in 1st going about 5Mph.
it sounded like i had ranout fo petrol but i diddnt, radiator has some mud on it, nothing major, just a small strip from the road crap flinging of my tyre.
i stopped, then tyred to pull away, nothing...so i got the bike on the pavementand it was ticking over fine, normal speed of tickover...i waited for about 30 seconds for my m8 stu who screamed off ahead to come back...but diddnt, so i attempted to pul away and the bike was behaving completly normal again...later on about a mile down the road it did it again, pulled over waited and then continued, this happened about 4 times on the way home from where ever we where...
Any ideas ?
i think too much oil and not enough pertol
Rieju RS2 50cc MATRIX Race Replica - Cagiva Mito 125 - VFR400 NC30
LukeVFR: Cog Head is a Karma whore Shifty
McGee: Hence I smell like a gimp
steveh
PostPosted: 00:24 - 26 Jan 2006    Post subject: Reply with quote
im guessing its a Rieju RS2 50cc, could of said, i had this with mine, oil was getting into the air filter box and doing the above, clean the air filter, or change it, set the mixture, if all else fails, check your piston and barrel.
Steve.
Cog Head
PostPosted: 00:38 - 26 Jan 2006    Post subject: Reply with quote
Steve.
Shifty actually...now you mention it...i did see some luquid in my airbox when i had all my fairings off a while ago...
how do i set the mixture, and is it advisable for me to do it myself as i have fitted a race exhaust and have been told it need re-jetting... Neutral
cheers Thumbs Up Mr. Green
Superlight
PostPosted: 00:39 - 26 Jan 2006    Post subject: Reply with quote
Sounds like it could be carburettor icing. (Put simply - moisture in atmosphere freezes in carb, then defrosts when you're stationary with the engine running, freezes up again when you get going.)
Assuming that there's nothing wrong with the carb, and you're using decent oil, there may not be much you can do about it.
The best solution - don't ride when it's cold. Thumbs Down
You only need two tools: WD-40 and Duct Tape.
If it doesn't move but should, use the WD-40.
If it shouldn't move but does, use the Duct Tape.
Superlight
PostPosted: 00:40 - 26 Jan 2006    Post subject: Reply with quote
Then again, it could be what he said! Confused
Cog Head
PostPosted: 00:49 - 26 Jan 2006    Post subject: Reply with quote
that sounds about right actually, as it was icy out there, and i was bloody cold Shocked , i dont think i could pay anymore for my oil if i tryed, i pay £10 for a litre of castrol TTS fully synth,
ill give the filter a blast and maybe get a proformance one when i get my carb jetted to my exhaust
PostPosted: 00:56 - 26 Jan 2006    Post subject: Reply with quote
Carb icing would be possible, but not that likely. Not damp today and carb icing shouldn't be as common as people think.
My guess would be that the fuel tank breather is blocked. Fuel leaves the tank and air needs to get in to replace it. If the breather is blocked then the air cannot get in which slows down and eventually stops the fuel getting out.
Next time it does it open the petrol cap (as quickly as you can) and listen to see if you can hear a sudden rush of air going in. Also see if the bike then runs fine for a short while.
Cog Head
PostPosted: 01:07 - 26 Jan 2006    Post subject: Reply with quote
Hmmm... will do...
but when i pulled over it was ticking over fine...but it sound like that could be the reason too...AGH!!! i dont know what to do Sad
PostPosted: 12:48 - 26 Jan 2006    Post subject: Reply with quote
Cog Head wrote:
Hmmm... will do...
Just give it a try. Even better, take a spare key with you so you can open the tank with the engine still running and see if it suddenly perks up and is able to rev (ie, within a few seconds or so).
Not sure where the breather is on your bike, but if it is built into the petrol cap then there is the possibility that something moved and blocked it when you filled with petrol.
the grim reaper
PostPosted: 13:38 - 26 Jan 2006    Post subject: Reply with quote
If it was the fuel breather, it would probably stall as the carb bowls would be empty and would need the blockage to be cleared to fill up again. It could be that the rate of fuel being used slows to less than is allowed to flow by the vacuum, whilst idling, but it's unlikely.
Carb icing would be my guess, Pro FST is your friend.
Grim
PostPosted: 13:57 - 26 Jan 2006    Post subject: Reply with quote
Suffered blocked breathers and fuel filters on several occasions over the years, resulting in greatly reduced fuel flow. Each time the bike has idled fine, and only had problems when you open the throttle, and left idling for a while it would also clear as the fuel consumption is tiny at that point (but rapidly die again after a short distance).
Still think carb icing is unlikely as although it was cold it was not that damp, and the damp is largely what causes it.
ancientd
PostPosted: 14:32 - 26 Jan 2006    Post subject: Reply with quote
Icing on carburated bikes is common in the UK at any temperature below 5 degrees C. Some bikes suffer others are OK, my Thundercat suffers every year between November and April. The simple solution is a 2% mixture of Silcolene Pro FST added to the fuel. Icing is getting rarer these days as most bikes are being produced with fuel injection instead of carburettors.
I ride 3 bikes, a Thundercat, an FZRexup 1000 Streetfighter and a Jawa 350 Combo, something for all seasons.
Bezzer
PostPosted: 16:36 - 26 Jan 2006    Post subject: Reply with quote
It won't be carb icing, if the symptoms are as bad as said it would cut out when he slowed right down as the idle circuit is most affected by the ice.
Has it got a tank overflow vent as well as a tank breather?? Seen it before where the tank breather was clogged so it breathed through the overflow vent, fill up with petrol and you block that air route causing the vacuum and loss of fuel to the carbs.
ancientd
PostPosted: 16:55 - 26 Jan 2006    Post subject: Reply with quote
In some single carb systems the idle jet closer to the engine on a seperate system and hence is liable to be a little warmer and as it's not continually pushing fuel into the system dosen't ice up under normal running. It's certainly fuel starvation of some sort, could be a blocked main jet or the tank vent, the only way to be certain is too repeat the symptoms then remove the petrol tank cap to see if a partial vacuum had been formed. Without knowing the exact make and model of bike it's difficult to diagnose, certainly it's typical of some multi cylinder bikes except for the continual idling as you so rightly say
PostPosted: 16:58 - 26 Jan 2006    Post subject: Reply with quote
However the problem is not caused purely by the cold. It occurs because the air going through the carb and the fuel being taken from the carb reduces the temperature such that moisture in the air freezes. Not enough moisture and you will not get carb icing (and the temperature will rapidly drop to the point where carb icing does not occur because the cold air will not hold enough moisture).
Given that although it has been cold the past few days it has also been dry I would be surprised if there was enough moisture to cause carb icing.
Hadn't thought about it but agree with Bezzer that carb icing normally affects the idle circuit resulting in a bike that will run OK at high revs / throttle positions but not at idle, the opposite of the problem he is having.
Agreed, although it is also a problem that rarely bothered anyone with bikes until the late 80s. Quite likely that a substantial part of the icing problem is actually changes in the fuels used, with more modern fuels taking more heat from the carb body when they are drawn into the engine.
ancientd
PostPosted: 17:09 - 26 Jan 2006    Post subject: Reply with quote
With humidity above 80% and temperatures below 3 degrees I would have thought any bike that was liable to ice up will, particularly on a sustained highish speed run. I permanently run the Cat on a 2% PRO FST mix from November to April and don't have any problems, had a reminder back in November, I hadn't put any in as it seemed warm, went out early one morning and stopped after 12 miles. Crept home to get the FST in the tank.
Chiz
PostPosted: 18:57 - 26 Jan 2006    Post subject: Reply with quote
I'd go with carb icing. My mates RX50 always iced up when it was cold, i think most of the 50cc geared engines are the same (minarelli AM6), try some silkolene stuff, always did the trick for him.
Cog Head
PostPosted: 19:15 - 26 Jan 2006    Post subject: Reply with quote
i went for a little ride about erlyer, to book my bike into Bike tec neer me, to get my carb jetted for my race exhaust, and then went to a few shops to try to find some not stupidly priced mesh for the vents in my fairings and the LH side had died for some reason Confused , but seemed ok, i was purposely giving it some every where to try to get it to do it again, but nothing, so may be carb icing...
Ow yeah i got back in and cleaned my bike, i finished it and went around the block just for the sake of it. got back and rolled my bike backwords into my garage and pulled the front break and, clunk Shocked , one of the bolts has grown legs and flew away Shocked Evil or Very Mad
looked every where for it...i think its a 9-10 mil bolt as i put a 8.8 in and it wobbled a little when i screwed it in...
Bezzer
PostPosted: 20:50 - 26 Jan 2006    Post subject: Reply with quote
8.8. is not the bolt size, it is the bolts material type that is stamped on the head. ie 8.8 Grade steel
Cog Head
PostPosted: 21:09 - 26 Jan 2006    Post subject: Reply with quote
i see... then those bolts i rtyed where 8 mil and iv just tryed a 10 mil and its just too big, so it looks like its a 9 mil bolt that im missing
Bezzer
PostPosted: 21:32 - 26 Jan 2006    Post subject: Reply with quote
Doubt it's a 9mm thread probably won't ever find one on a bike, it might be the thread is slightly knackered in the hole it dropped out of so the 8mm bolt is a sloppy fit.
If it's holding something important then you'll have to sort it properly - helicoil etc, if its just cosmetic then use some thread lock.
PostPosted: 01:47 - 27 Jan 2006    Post subject: Reply with quote
Not ever seen an M9 bolt for sale (probably available, but not generally used). For a brake caliper I would buy an original bolt from the dealer. Having the mounting bolts shear off when braking hard as they are the wrong grade would not be fun.
Cog Head
PostPosted: 14:28 - 27 Jan 2006    Post subject: Reply with quote
Good point...im going to remove the bottom fixing bolt and take it to sutton motorcycles and bike tec to see if they have one. if not ill just wait for me dad to come home tonight to have a look see if we have any bolts to fit...
The last post was made 20 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 130.21 Kb
