| simon1221 |
 simon1221 World Chat Champion
 Posted: 23:11 - 26 Jan 2006 Post subject: Anybody know how the fuel system works on an old tzr? |
Its not as dumb as it sounds.
Fuel tank >> Carb >> Engine
But the problem is that after running for a while at average revs (7 - 8000rpm) the bike just dies and bogs down if you open the throttle.
If you wait a few seconds it will pick back up again but then I just give up and ride slower.
It sounds like fuel starvation but Im curious as to whether it could be something to do with the tank (breather pipes?) and possibly the carb as I raised the tang a little to stop fuel leaking out but it wouldnt cause this completely?
I wuold love to take it apart and see but Im not really sure where to look and its cold in my garage. Any ideas? ____________________ DNA50 (sorry) ->> TZR125l >> GPZ500S |
| Barry_M2 |
 Barry_M2 World Chat Champion
 Posted: 23:26 - 26 Jan 2006 Post subject: |
Blocked fuel filter (if you have one fitted)?
Low float height?
| www.125power.com |
 www.125power.com Crazy Courier
 Posted: 01:42 - 28 Jan 2006 Post subject: |
Think they are gravity fed, look on your petrol tank tap if theres two pipes on the tap chances are its gravity fed, one will go to carb other will go to cylinder, give the one that goes to the cylinder a suck and petrol should "piss" out of the other one for as long as you suck (use for checking petrol tap works)
Check the float does not stick, and jet jets are clear
Also on some carbs (not sure if this applies to yours) just above the overflow pipe there will be a small screw that controls how fast or slow the carb will "empty" itself if it overfills check it isnt just dumping all your petrol as you wind it on ____________________ My eBay Items |
 Posted: 11:53 - 28 Jan 2006 Post subject: |
If it runs for a while then starts to die I would doubt it is the floats (they just keep the fuel height in the float bowls constant so the problem would occur however long it has been running).
Fairly certain the TZR doesn't have a vacuum fuel tap.
That leaves the fuel tank breather and any filters in the system. You can try riding with the fuel cap loose to confirm / eliminate the breather and see it it solves the problem, but be careful that you do not spill fuel all over the place.
Also consider draining the fuel tank and cleaning out the filter built into the fuel tap (generally a piece of gauze tube the shape and size of a cigarette). Also gives you a chance to check the contents of the fuel tank (and see just how much water has accumulated in there).
| simon1221 |
 Posted: 19:22 - 28 Jan 2006 Post subject: |
It will run fine at lower revs all day without any problems, its only the higher revs that are the problem.
Il have to wait a while before testing it thought as I only just filled up yesterday
This carb has some sort of drain screw but it is stuck solid so thats a no go.
Cheers for the help I will test it in a week or so when there is less fuel in there. ____________________ DNA50 (sorry) ->> TZR125l >> GPZ500S |
The last post was made 20 years, 234 days ago. Instead of replying here, would creating a new thread be more useful? |
