| shammon |
 shammon World Chat Champion
 Posted: 23:57 - 07 Dec 2005 Post subject: front Disc brakes no pressure |
started to re assemble the brakes as no pressure when went to bleed them again on my Yamaha xj600 pre divy, Firts prob was bleed valves were blocked, then dirt in the resiviour, after cleaning and new pads....no pressure at all in handle.'
Master cylnder workes removed it and pressure from piston.
pipes free of debri etc., inc connection holes.
re assembled air bled and again no pressure again no leaks, then noticed no bite at all at the pistons or pressure on the pads so calipers pistons seized. what i need to know
1 is this what happens when the calipers on both sides seize
2 how the hell do i get them out to renew seals if i cant get pressure to pop them?
3 I would have thought there would be some pressure in the system still but no so could the master cylnder not be able to give enough pressure?
Cheers. ____________________ YAMAHA YZF 1000cc THUNDERACE- 'ƃuıןןǝds ʇnoqɐ ʇıɥs ɐ ǝʌıƃ ʇuop ı |
| Bezzer |
 Bezzer World Chat Champion
| shammon |
 Posted: 00:23 - 08 Dec 2005 Post subject: |
Thanks. ____________________ YAMAHA YZF 1000cc THUNDERACE- 'ƃuıןןǝds ʇnoqɐ ʇıɥs ɐ ǝʌıƃ ʇuop ı |
 Posted: 12:02 - 08 Dec 2005 Post subject: |
As above. But a few other things to try.
You can use a large syringe to push fluid in through the bleed nipple (filling the system from the bottom). Can be messy though.
Also take the reservior cap off. Now pull the lever slightly. Often you will see some bubbles come up through the fluid. Release and repeat. Often only needs a tiny amount of lever movement (and pulling the lever fully tends to force the air into the system so you have to wait for it to rise up again). You can also tap the brake lines to encourage the air to the top.
Lastly wrap a cloth around the top banjo and put a spanner in place on it. Pull the lever hard and then crack off the top banjo and then do it up again before releasing the lever. Often the banjo is the highest part of the system and air bubbles tend to get stuck there.
| shammon |
 Posted: 22:04 - 28 Jan 2006 Post subject: |
Just an update on how it was sorted
Force fed fluid through the bleed nipple up to expel air
Pushed back pistons fully to dispel air then re fitted and bled system again
Finaly the brake handle pin which pushes the master cylnder plunger in had to be re adjusted this is where most of the lack of pressure was comming from, often shows you how simple things sort that big prob.
Andy ____________________ YAMAHA YZF 1000cc THUNDERACE- 'ƃuıןןǝds ʇnoqɐ ʇıɥs ɐ ǝʌıƃ ʇuop ı |
The last post was made 20 years, 231 days ago. Instead of replying here, would creating a new thread be more useful? |
