Wanted: Old pc's with reasonable hard disk space
Bike Chat Forums Index -> Bikes & Accessories Goto page 1, 2  Next
PostPosted: 14:35 - 15 Apr 2003    Post subject: Wanted: Old pc's with reasonable hard disk space Reply with quote
anyone know somewhere cheap to get old boxes with reasonable amounts of disk space in em?
I just need to be able to network them up cos this pc is full Sad
PostPosted: 14:38 - 15 Apr 2003    Post subject: Re: Wanted: Old pc's with reasonable hard disk space Reply with quote
How old, how much disk space?
PostPosted: 14:41 - 15 Apr 2003    Post subject: Reply with quote
any age, as much disk as poss
Cool
Demonic69
The Pink Rhino
PostPosted: 17:35 - 15 Apr 2003    Post subject: Reply with quote
Just buy a PCI ATA controller and a fuck-off big HD
Back on a Blade. Just feels so right.
PostPosted: 17:40 - 15 Apr 2003    Post subject: Reply with quote
Yea... you can get 'em for £25 for a Raid 0,1 or less for no Raid.
I'm intending to put one in a pc as a server... so with 8 HDs in total of varying sizes.
If you want computers, I got em... yours for the taking <233MHz ish.
If you want faster I got a couple of 400MHz lying around in various states of working Smile.. though I would want something for those.
Korn
Admin
PostPosted: 17:54 - 15 Apr 2003    Post subject: Reply with quote
I've got a 4 channel Promise controller with 2 x 160gb + 2 x 80gb Maxtor drives in JBOD configuration - the controller came free with one of the 160gb drives. It's great in one way because you retain the 4 channels on the motherboard for a boot drive and CD drives, plus you can use the array as one big drive instead of 4 smaller ones.
The problem is extending it. I've now filled it up and to add another drive I'm going to need to rebuild the whole thing which means finding somewhere to put 480gb temporarily - not going to be easy. Oh, and if one of the four drives dies - the whole array is fucked Confused. If I was doing it again I'd get a better controller and build a Raid 5 array instead, less disk space for the same money but it would be extendible and one drive failing wouldn't lose you all your data.
3516 Miles, 11 Countries
PostPosted: 18:01 - 15 Apr 2003    Post subject: Reply with quote
Korn: wtf have u managed to fll 480gigs worth with!! That takes some doing Shocked
G: wot disks have the <233mhz got in em?
Doddmaster
PostPosted: 18:03 - 15 Apr 2003    Post subject: Reply with quote
Give me 480gb of space and I'd fill it up with porn in 2 days max Smile
Demonic69
The Pink Rhino
PostPosted: 18:04 - 15 Apr 2003    Post subject: Reply with quote
I wouldn't bother with RAID on an IDE Array.
If you want some decent storage get a NAS like a Snapserver.
Yeah, but 480 gigs of stuff.
/me points korn at dvd burners
Demonic69
The Pink Rhino
PostPosted: 18:06 - 15 Apr 2003    Post subject: Reply with quote
Yeeeeeeeah. He'd only need to burn about 100 DVD's to clear some space.
zaknafien
PostPosted: 18:37 - 15 Apr 2003    Post subject: Reply with quote
/me points to copious amount of pr0n CD's stacked in the corner.
Korns got nothing on me Razz
02 Firestorm.
We have 5x80gb in a Raid 5 array at work (4 in array + 1 failover)... and IMO it's loads better than other similarly priced options. It's dfefinatley a lot faster than a SCSI soloution at a similar price (128mb cache helps Smile )
The only prob is a Hardware RAID 5 card (go for the promise, 'cos it has 6 channels while the Adaptec has 4) is that it's £300 ish for the card.
I was actually thinking along the lines of this the other night:
6x120gb drives + Raid 5 card= 6x£100+£300=£900
Which gives 600gb Useable space
While
8x120gb + 2 x Raid 0,1 cards=8x£100 + 2 x 25= £850
Which would give you 480Gb in a Raid 10 array
However it would be much easier to start small with this configuration and it has a lot more redundany.
You can always consider Software Raid courtesy of M$ ... (need server for Raid 5 I believe... not sure of how good it really is) I wouldn't be suprised if it actually slowed the transfer rate down, but that's not always an issue.
I wasn't aware you can just add disks to a RAID 5 array.. none of the Dells we use it ley you do it AFAIK, and I don't think the promise card does... shall investigate if I got particularly bored at some point Smile
And I'm sure we can workout what takes up all that space on Korn's hard discs Razz
Demonic69
The Pink Rhino
PostPosted: 10:46 - 16 Apr 2003    Post subject: Reply with quote
You have to reset the RAID array if you're adding disks as the parity disk needs to re-configure what's put in.
PostPosted: 11:00 - 16 Apr 2003    Post subject: Reply with quote
Raid 5 uses striped Parity I believe... Raid 3 has a seperate disk... but yea, same thing.
Demonic69
The Pink Rhino
PostPosted: 13:18 - 16 Apr 2003    Post subject: Reply with quote
Raid 5 uses 1 disk for parity. RAID 3 doesn't exist AFAIK
zaknafien
PostPosted: 13:19 - 16 Apr 2003    Post subject: Reply with quote
Demonic69 wrote:
AFAIK
Which, if your honest isnt very much Razz
02 Firestorm.
Demonic69
The Pink Rhino
PostPosted: 13:27 - 16 Apr 2003    Post subject: Reply with quote
Razz
Shaddap Fugly.
zaknafien
PostPosted: 13:28 - 16 Apr 2003    Post subject: Reply with quote
Ta muchly Smile
02 Firestorm.
PostPosted: 13:53 - 16 Apr 2003    Post subject: Reply with quote
RAID 5 uses 1 disks /worth/ of space for the parity, however this is striped accross all the disks. RAID 3 has one specific disk dedicated to the parity.
Can't be bothered to google .. but I'm, pretty sure that's the way it is.
RAID 3 /does/ exist, it's little used... there's pretty much all the RAID numbers between 0-10 that have been created by one company or another... of the minor ones 3 is more well known.
PostPosted: 13:55 - 16 Apr 2003    Post subject: Reply with quote
googled:
https://www.recoverdata.com/raidfaq.htm
Korn
Admin
PostPosted: 14:34 - 16 Apr 2003    Post subject: Reply with quote
It's not actually porn. Mosly DivX movies (I think I've ammased 200+ now) and episodes from TV series. I have a seperate 160gb disk which has porn on it (I need a lot of it for work, you see), and it's not even half full Crying or Very sad
G wrote:
I was actually thinking along the lines of this the other night: 6x120gb drives + Raid 5 card= 6x£100+£300=£900
I built a spreadsheet a few weeks ago to do this type of calculation and 120gb drives came out cheapest for me as well.
The current plan is to get hold of a DAT drive, back up my 480gb of stuff and sell that array, then buy six Maxtor 200 gig drives (not an obvious choice but a mate's business has a pallette they're selling off uber cheap) and build a new array for 1 gig of space. Just need to knock off a few post offices first Razz
PostPosted: 14:57 - 16 Apr 2003    Post subject: Reply with quote
How cheap is 'uber cheap' then? Smile
Korn
Admin
PostPosted: 15:22 - 16 Apr 2003    Post subject: Reply with quote
When he first told me about it he was knocking them out for £50!! I promptly adivsed him to double the price, silly twot.
PostPosted: 15:46 - 16 Apr 2003    Post subject: Reply with quote
Go and tell him that prices have come down again £25 is reasonable now Smile... and I'll have 10 Razz
If anymore are availalble I might be interested.
The last post was made 23 years, 141 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 125.88 Kb
