Whats up with my lemon??
PostPosted: 18:37 - 30 Jan 2006    Post subject: Whats up with my lemon?? Reply with quote
I think I brought I bit of a dogdy bike it's a bandit 600 k1. It wouldn't start for a while but new plugs cured that.
I'm not riding it as I don't have a licence but my dad is and I'm at uni away from home.
He has just told me that he doesn't think it's at full performance (He says he doesn't think it's as powerful as his CX500) and it's going through fuel too quick from a full tank it came onto reserve at 77 miles! (there are no fuel leaks)
anyone know what this is???
also the rev counter is broken he says he has checked the wireing and taken the clock apart and can't see what is up with it.
numark1
Scared of girls
PostPosted: 18:51 - 30 Jan 2006    Post subject: Reply with quote
Have a ganders at the air filter. Thumbs Up
feef
Energiser Bunny
PostPosted: 23:50 - 30 Jan 2006    Post subject: Reply with quote
could be a perforated diaphram in the carb? (not suer if they have them ion bandit's tho), or some other problem in the carb. meaning the engine runs a bit rich. fouls the plugs after a while, sooks up petrol like nothing, and fecks the power.
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
bish777
PostPosted: 01:59 - 31 Jan 2006    Post subject: Reply with quote
youll need to check the float heights, all the carb gaskets etc and the air filter.
Also check the main jet sizes, possibly someone has jetted it up for pod filters or similar and then stuff oe airbox or whatever back on.
check out www.oldskoolsuzki.info
GSXR1100J
PostPosted: 13:38 - 31 Jan 2006    Post subject: Reply with quote
Check that the fuel is not leaking into the engine while parked (can easily happen if the fuel tap is left on prime). Likely to result in the oil level going up as petrol gets into the cylinders, past the rings and dilutes the oil.
Check the carbs over carefully. Quite possible that someone has played with them for another pipe. Check the airbox lid as it is common on Bandits to cut a hole in this to increase airflow and if this is done it would suggest the carbs have been played with. Check the car needles and see if the needle position is adjustable which would suggest Dynojet or equivalent ones fitted.
Also check the choke cable is not sticking.
77 miles is rediculous. At a push I can get double that out of the 1200 Bandit before hitting reserve.
PostPosted: 14:40 - 31 Jan 2006    Post subject: Reply with quote
Thanks guys I'll ask my dad to check these out. Thumbs Up
The last post was made 20 years, 202 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 50.18 Kb
