HMS Daring launch
Bike Chat Forums Index -> Politics & Current Affairs Goto page 1, 2  Next
Mister James
I want to believe!
PostPosted: 13:15 - 01 Feb 2006    Post subject: HMS Daring launch Reply with quote
As some of you may know, the Royal Navy's most advanced warship is going to be launched this afternoon on the Clyde. I've been following the progress of this project since it was announced, I'm surprised that it hasn't been cut or neutered by good old Gordon Brown, especially at a cost of £650 million per unit!
https://news.bbc.co.uk/1/hi/scotland/4666906.stm
The PAAMS radar system and ASTER missiles do wee-wee all over the american AEGIS system, giving us the most advanced and powerful air defence naval platform in the world. It's also the first major surface combatant to employ a fully electric drive system.
carvell
Scuttler
PostPosted: 13:17 - 01 Feb 2006    Post subject: Reply with quote
Ooooo I've been following the progress of the Type 45's a fair bit too, didn't realise they were going to launch the first today! Certainly proves to be a landmark event for the Navy!
Yamaha TDM 850
tribal_tiger
PostPosted: 13:19 - 01 Feb 2006    Post subject: Reply with quote
BBC wrote:
"When she comes into service in 2009, we're going to have the most advanced warship in the world.
What's it going to do until then?????
Looks cool, but it seems really tall for it's length looking at those pics!
How much wood would a woodchuck chuck if a woodchuck could Chuck Norris?
All of it.
Mister James
I want to believe!
PostPosted: 13:21 - 01 Feb 2006    Post subject: Reply with quote
Doesn't come into full service until around 2009, although we might find that the date gets brought forward a bit, from the sound of things, they are improving their construction methods as they go. The two following sister ships under construction are already fitted out to a state you would only expect 2 years after their launch, rather than nearly a year before it.
Can't come too soon, the type 42s were long in the tooth a decade ago - they are close to useless as a modern air defence picket ship.
Mister James
I want to believe!
PostPosted: 13:23 - 01 Feb 2006    Post subject: Reply with quote
Fitting out - ie. adding the weapons, internals, computers, fire control, beds, furniture etc.
Then contractor's sea trials to make sure she's fit for service, then the Navy plays with it some, trains a bit, plays some more, tries to break it, then accepts her into the fleet.
With regards to the tall mast - the higher up the radar, the further over the horizon it can see. When you are defending high-value units such as a carrier or assault ship, every extra second you can grab to intercept a missile or aircraft is precious.
The closer a missile gets to the fleet, the more likely it is that even if you destroy it, the supersonic debris shreds your radar and weapons and effectively mission-kills you.
carvell
Scuttler
I imagine it's not been fitted out inside to a very high standard yet. Until 2009 they'll be finishing it off and assigning it some crew and whatnot.
It's not /that/ much taller than the Type 42's. Need to get the RADAR up high to see stuff for hundreds of miles.
Yamaha TDM 850
PostPosted: 14:09 - 01 Feb 2006    Post subject: Reply with quote
Twenty odd years ago, after the Falklands, they were talking about the lessons from that war. One major problem with the type 42s (and the like) was that they were found to be poor in heavy seas. The proposals at the time were that their replacement would be much broader to help their stability. Seems that they have gone for this a bit, but not as much as they talked about at the time.
How does the electric drive system work? Are they using a gas turbine to generate electrical power for the drive system?
map
Mr Calendar
PostPosted: 14:14 - 01 Feb 2006    Post subject: Reply with quote
Looks interesting but with all those flat surfaces IMO it looks like it's hardly invisible to radar itself.
Mister James
I want to believe!
PostPosted: 14:26 - 01 Feb 2006    Post subject: Reply with quote
Aye, I remember the designs for a 'fat' frigate when I was a kid. Model tests showed that it would make a stable weapons platform under some conditions, but I seem to remember that having a wider beam and shorter length caused other performance problems. Weapons systems became more sophisticated and morecapable of self-stablising, and the tried and tested nature of conventional 'long hulls' meant that their supporters found it easy to just stick on stabilisers and increase the beam ratios, while the radical designers had to try and design a total departure from the norm to compete. In the end, they couldn't prove their case enough to persuade the government to take the risk.
To be honest, the fact that no government in the world has built a model that mirrors the original 'fat' concept suggests that further tests/simulations showed it wasn't as good as they first thought.
Our MV Triton trimarine is probably the closest thing around, and has attracted a fair amount of interest from other navies. There are some pretty cool concept sketches for it's possible influence on the design of our FSC - the replacement for our frigate fleet, I'll attach a couple at the bottom.
Yup. As I understand it, there is a turbine system providing the power for the ship as normal, but the prop shafts are directly connected to electric motors. It's apparantly much more efficient, as you have total control without needing reduction gearing from the turbines, which are effectively ripped out of jet planes.
If you look at the angles, you'll notice most of them direct the radar beams away from the transmitting unit - effectively reducing the radar signature of the ship. I assume that'll be used in conjunction with Radar Absorbing Materials on awkard parts of the ship.
tribal_tiger
PostPosted: 14:39 - 01 Feb 2006    Post subject: Reply with quote
They should have come to me for the deign. Mine can roundhouse other ships while it pities the hell out of them!
It wants to appear on radar, It saves time.
All of it.
PostPosted: 14:40 - 01 Feb 2006    Post subject: Reply with quote
Interesting. I can see that it would have speed issues, but not sure how relevant they would be on a picket ship.
One of the other things I remember was that they were talking about having multiple vertically mounted weapons launchers, mounted below the decks. Presume they gave that idea up with improvements in the time to reload.
From (vague) memory part of the problem was that to keep the type 42s seaworthy (let alone as a good weapons platform) they had to play around with the fuel tanks for ballast (from even more vague memory, flooding some of them with sea water when empty which caused other problems afterwards).
Quite probably true, although also how many new designs have gone into service since then? Takes a hell of a long time to design and build any new military equipment these days.
Mister James
I want to believe!
PostPosted: 14:54 - 01 Feb 2006    Post subject: Reply with quote
Any blue-water navy such as the RN needs escorts than can keep up with carriers, which steam at around 30 knots. I guess they went for the compromise - both the types 45 and 23 show wider beams than a 42 or 22, in relation to their length.
The 23's already have these to launch their seawolfs, a group of 32 vertical launch tubes between the bridge and the 4.5" gun. The 45's will also have them, and should be able to fit modular packs that let them launch various missiles in addition to their standard issue Asters.
Aye, sounds about right. After the Falklands conflict there was a panic-stricken rush in every major navy to take on-board the various lessons learnt by the RN. Metal ships can burn, missile only weapon-fits are a bad idea, type 21's fall apart if they are put under any stress, that kinda thing!
Definitely. There is a lot of inertia in the so-called military/industrial complex, and often convenience has to come first. As you point out, sophisticated weapons platforms can take decades to develop and build - who is going to seriously consider risking a radical departure from accepted wisdom on ship dimensions?
I still stick by my earlier comments, aside from the trimarine concepts, even the wackier american concepts do not go that far in addressing the beam issue, suggesting to me that they eventually decided it was not worth the hassle for some reason.
Hex
Party Boy
PostPosted: 15:02 - 01 Feb 2006    Post subject: Reply with quote
Oh you have no idea, I don't work with the deep blues too much and when I do its always their air capabilities ie SeaKings, Lynx, Tornados etc.
The delays that things go through in development is stupid. During the life of the 45's to this point there has been stupid amounts to changes due to budgets, time scales etc. Pound to a penny they come in underspecked to what was wanted and are late.
Thats a guarantee from someone on the inside.
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
ZRX61
Victor Meldrew
PostPosted: 16:19 - 01 Feb 2006    Post subject: Re: HMS Daring launch Reply with quote
Lets hope that in the fog of war someone doesn't forget to put 50p in the meter.... Rolling Eyes
zaknafien
PostPosted: 16:40 - 01 Feb 2006    Post subject: Reply with quote
And we have a grand total of...
Wait for it!
1 and it wont be ready for another 3 years. Confused
BTW, if you go on google earch and visit portsmouth you can see the triton docked.
02 Firestorm.
zaknafien
PostPosted: 16:46 - 01 Feb 2006    Post subject: Reply with quote
Here.
02 Firestorm.
Mister James
I want to believe!
PostPosted: 17:24 - 01 Feb 2006    Post subject: Reply with quote
Wait for it!
I believe Dauntless and Diamond aren't far behind Daring, construction-wise. Another 3 will be started soon.
Mister James
I want to believe!
PostPosted: 02:54 - 02 Feb 2006    Post subject: Reply with quote
Wow - another useless factoid - apparantly the radar system is so powerful that from Portsmouth it could monitor landings and takeoffs from every major european airport!
Jman
PostPosted: 01:03 - 28 Feb 2006    Post subject: Reply with quote
i reckon radar absorbing paint is more likely. radar absorbing materials used in fighters don't do much for the armour and while there are weight issues to consider with aircraft, you can't go increasing the density of the material to the point where it makes a decent defence against the modern array of SSMs and then use it all over the ship because it will probably sink. far easier (to maintain aswell) to just use the paint. its a proven technology.
please do not touch as fondling may excite
killa
Won't Shut Up
PostPosted: 09:32 - 28 Feb 2006    Post subject: Reply with quote
Why don’t we just make the biggest battle ship ever so it holds the most guns?
Why can’t we make force fields yet?
Does that new ship have an oven?
killa
Won't Shut Up
PostPosted: 12:02 - 28 Feb 2006    Post subject: Reply with quote
Has anyone got that picture of the air craft carrier docked in America and it’s absolutely huge?
zaknafien
PostPosted: 18:30 - 28 Feb 2006    Post subject: Reply with quote
Because it would be a useless waste of money.
Which one? They have serveral of them.
02 Firestorm.
McGee
O RLY?
PostPosted: 18:56 - 28 Feb 2006    Post subject: Reply with quote
Zak I would be interested to see any of the big ones Thumbs Up
Its pronounced Jixxer!
sickpup
Old Timer
PostPosted: 19:22 - 28 Feb 2006    Post subject: Reply with quote
American aircraft carriers even with there large escorts have been taken out in war games by the British using much smaller craft.
I heard from a mate who's ex-aussie navy that they have managed it as well.
Don't put all your eggs in one basket.
zaknafien
PostPosted: 19:27 - 28 Feb 2006    Post subject: Reply with quote
USS Ronald Reagan, the 9th nimitz class of the US fleet.
100,000 ton's
https://captsan.com/images/Scott/USS_Ronald_Reagan/USS%20Ronald%20Reagan%20CVN%2076-3.jpg
https://upload.wikimedia.org/wikipedia/en/thumb/5/5f/Uss_ronald_reagan_cvn-76.jpg/300px-Uss_ronald_reagan_cvn-76.jpg
02 Firestorm.
The last post was made 20 years, 189 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 145.17 Kb
