Backfiring When Bumpy
DukeRed
PostPosted: 21:52 - 01 Feb 2006    Post subject: Backfiring When Bumpy Reply with quote
Went over an invisible speed bump far too fast last week on the TRX.
Since then it has a tendancy to backfiring when going over big bumps but only when I have the throttle fairly open. I noticed it didn't seem to do it when I had a pillion but it might just be because I was more gentle. Oil/Filter change 800miles ago meant to be every 500 if that would make any difference. Only other things I've done to it are changing to shorter tie bars and dropping front suspension but can't imagine that makes a difference.
Saying everything since it might be important.
Cheers Thumbs Up
Enjoy Life There's Plenty of Time to be Dead
https://www.janoner.com
PostPosted: 21:59 - 01 Feb 2006    Post subject: Reply with quote
A common cause of backfiring is an interruption of the power supplying the spark (as if you flicked the kill switch).
So, could be that when you go over a bump, something is momentarily switching the power off. How about the sidestand bouncing away from the cutout switch as you go over a bump?
Failing that, I'd make sure the battery terminals are tight and check the wiring where it goes past the bodywork, under the tank and the past the headstock for chaffing.
Another cause of backfiring is an air leak in the exhaust system. Could you have dinged it when you went over the bump and loosened one of the joints?
My money is on the sidestand though.
DukeRed
PostPosted: 22:09 - 01 Feb 2006    Post subject: Reply with quote
Now that you say it I've always had to put it in neutral to start even when clutch in. Once it's started once though I can start it with clutch in , in gear.
Also got the bike stuck on the exhausts the other day going over a two foot curb so could be that.
Or could be the fact that I don't have a kill switch and the wires are tapped up.
Cheers again Stinkwheel Thumbs Up permanent font of knowledge.
sickpup
Old Timer
PostPosted: 02:25 - 02 Feb 2006    Post subject: Re: Backfiring When Bumpy Reply with quote
Cheers Thumbs Up
Well if fitting shorter tie bars raises the rear and you have dropped the front you could be causing the float bowls not to fill to the right height as you have changed their angle in relation to the horizontal. This could become a problem if the emulsion ubes point to the back of the bike.
Incidently Boyer used to make special float bowls for crossers to stop them burping and farting on rough ground.
DukeRed
PostPosted: 17:35 - 02 Feb 2006    Post subject: Reply with quote
This is where my knowledge of mechanics falls short. The TRX forum are constantly talking about emulsion tubes. What do they look like? Where would they be? What would indicate they pointed backwards?
I always imagined them to be thickish rubbery white tubes Confused .
DukeRed
PostPosted: 17:26 - 06 Feb 2006    Post subject: Reply with quote
Hmm, it appears to have got worse. It's not the side stand or battery connection. I doubt it's the kill switch.
Now when I go over big speed bumps 10mph with no throttle, clutch in the bike dies and I have to start it up again.
This makes me think it isn't an issue with the exhaust/ carbs etc and is definately something electrical. Anywhere else I could check? Had new sparks in about 3 months ago.
Edit - took it back to standard ride height but still did it so isn't float bowls.
bish777
PostPosted: 17:54 - 06 Feb 2006    Post subject: Reply with quote
just run through everything and make sure nothings loose, check the connector block to your ignition box for a start, or to the coil(s).
GSXR1100J
The last post was made 19 years, 358 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.4 - MySQL Queries: 13 - Page Size: 54.54 Kb
