Autocom Help...
Method
PostPosted: 15:13 - 02 Feb 2006    Post subject: Autocom Help... Reply with quote
Hey
Just bought an Autocom unit from ebay the other day, basically im having trouble fitting it into my helmet securely.
I have a Suomy Gunwind which has some strange kind of lining inside it, basically the velcro on the back of the speakers does not stick to my lining, and the same goes for my foggy mask too - but anyway,
Was just wondering if anyone a) had any ideas, and b) could maybe post a pic of how they have theirs set up inside their lid?
Just to give me a rough idea of what i can do to sort mine out, and how it should look when its set up properly Laughing
Thanks!
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
Black Knight
PostPosted: 15:21 - 02 Feb 2006    Post subject: Re: Autocom Help... Reply with quote
If you give them a ring they'll be more than happy to help you out.
Autocom - 01926 431249
My suggestion would be to use some sticky tabs and try and attach behind the fabric to the actual inner of the helmet.
Stickyback velcro is pretty secure and only cost a couple of quid.
Where does a turn end? 'Where you can do anything with the gas you want to, where you are brave again, where your attention is free from the turn, where you are sure you can do it better next time; that's the end' - Keith Code.
BFG
PostPosted: 15:35 - 02 Feb 2006    Post subject: Reply with quote
Autocom are in Warwick, near Birmingham. If you can get there, they will fit it for you free of charge.
I followed their recommended method. They said that on almost all helmets, the two cheek pieces pop out. They are not glued in, they are simply held in place by the chin piece liner. I found this to be true with my Craft RX9.
Re fitting the speakers, they told me to cut a slit in the lining of the cheek piece, and remove some foam from where the ear is, then insert the speaker into the gap you made. But you must work out the exact positon over the ear first.
I did this and the result is fantastic.
Method
PostPosted: 15:36 - 02 Feb 2006    Post subject: Reply with quote
Cant realy sitck them to the actual back of the helmet, behind the lining, because i wont be able to hear them... unless i make a tear in the lining, slide them through the tear...
nah thats not a great idea is it.
Ill give them a ring now, brb mate
Method
PostPosted: 15:38 - 02 Feb 2006    Post subject: Reply with quote
Method wrote:
...because i wont be able to hear them... unless i make a tear in the lining, slide them through the tear...
Laughing Great minds think along the same lines Laughing
Can get to Warwick but its about 80miles each way... maybe not.
Sounds like ill have to try this lining shit first i suppose.
Black Knight
PostPosted: 15:39 - 02 Feb 2006    Post subject: Reply with quote
How thick is your lining? On my helmet where your ears go its just a thin mesh. I could hear quite loudly through that.
Find the space for you ears in the helmet, put the speakers in that space or attach to the foam directly behind it.
Works fine for me.
Method
PostPosted: 15:59 - 02 Feb 2006    Post subject: Reply with quote
Cheers everyone! Just pulled the whole chin peice out and fitted the speakers into the padding around the foam. Feels sooo much more comfy, am just running downstairs to test it out with some music, g/f as pillion will come later tonight Thumbs Up
On a seperate note, anyone got any rough prices on extension leads for the headsets? I cant open the brochure from their website as i dont have acrabat Sad
JeffT
PostPosted: 21:44 - 02 Feb 2006    Post subject: Reply with quote
Method,
Go here: https://www.adobe.com/products/acrobat/readstep2.html
and you can download acrobat for free Smile
The last post was made 20 years, 248 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 60.59 Kb
