Engine Cut Out Problem
mcc
Guest
PostPosted: 10:44 - 17 Apr 2003    Post subject: Engine Cut Out Problem Reply with quote
Grateful for any assistance as I am a bit of a dork when it comes to anything technical.
I have a Hyosung 125cc 4 stroke scooter which has recently been serviced. However after travelling for 4 or 5 miles, when the engine has warmed up, the bike tends to periodically loose power, especially at low speeds and then cut out all together. I was told this may be due to lack of vacuum i the petrol tank but it cuts out on nearly a full tank of petrol. Could the carb need cleaning?
Thanks for your feedback in advance.
TiN
Pocket Tin
PostPosted: 10:52 - 17 Apr 2003    Post subject: Reply with quote
Did you have this problem before it got serviced? If not, then I'd take the scooter back to the garage and shout at them for a bit Smile
As for the vacuum, it's not how much fuel you have in the tank, it's how the air escapes from it to reduce pressure. There usually a piece of tubing coming from the bottom of your tank and leading to no-where.
There's a chance that either the vacuum hose or main fuel hose is kinked somewhere (as a result of dodgy mechanics messing with your bike), which would either lead to fuel or air starvation.
TiN
dotgems.net
Kris
PostPosted: 10:55 - 17 Apr 2003    Post subject: Reply with quote
make sure your breather pipes are okay and not kinked etc...
www.prisonplanet.com
mcc
Guest
PostPosted: 11:00 - 17 Apr 2003    Post subject: Reply with quote
Thanks for advice guys. It went back to the garage that done the service but they could find anything wrong with it. But as the problem stille exists then I'll go back again.
TiN
Pocket Tin
*cough* do I hear an echo in here? Laughing
TiN
dotgems.net
Kris
PostPosted: 11:06 - 17 Apr 2003    Post subject: Reply with quote
yea but no-one listens to you tin Razz
...those mirrors are in vipers safe hands now btw, thanks for your help mate Very Happy
TiN
Pocket Tin
PostPosted: 11:49 - 17 Apr 2003    Post subject: Reply with quote
no probs mate, I'm just glad that you've finally got the ruddy things!...so I guess that you weren't *that* desparate for them after all? Razz
TiN
dotgems.net
The last post was made 23 years, 47 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 50.41 Kb
