nsr carb help??
jimpuntoy
PostPosted: 17:58 - 04 Feb 2006    Post subject: nsr carb help?? Reply with quote
on the carb there is a big screw with a spring on it which i believe is to change the mixture? is this right? also what is the smaller screw just to te left of thiis big screw? and what would the corect settings be for both ? its a 1992 nsr125rk jc20 ?? Smile
1992nsr125rk ..
alains
PostPosted: 20:16 - 04 Feb 2006    Post subject: Reply with quote
the big screw is the throttle screw tightening gives more idle . the pother screw is the pilot screw which must be tighten and undo 2 1/2 turn (900°) . the throttle must be set (warm engine , out of blue zone on the temp clock) at 1400 rpm +-100
jimpuntoy
PostPosted: 13:51 - 05 Feb 2006    Post subject: Reply with quote
thanx done it, what difference now would ther be with carbon reeds in?
1992nsr125rk ..
alains
PostPosted: 14:24 - 05 Feb 2006    Post subject: Reply with quote
a bit of power increase and a smoother engine , because a better filling in mixture especially at high revs . note on your book when you fit them because after 3 years (or 6000 miles) it's better to change them .
jimpuntoy
PostPosted: 14:35 - 05 Feb 2006    Post subject: Reply with quote
id like to buy some cant understand the link you gave me in french maybe i can give u money on paypal to buy off you? ." for your reeds here is the link (it's in france £23 which is not too bad) https://www.blue-oil-france.com/default.php?cPath=210 ref 360451 " ?? Smile
1992nsr125rk ..
alains
PostPosted: 14:43 - 05 Feb 2006    Post subject: Reply with quote
ok , mate . send me a pm with your name & adress , i will get in touch with them then i will reply with the total price , because for delivery to me they charge 9 euros and i do not know how much for UK .
jimpuntoy
PostPosted: 14:50 - 05 Feb 2006    Post subject: Reply with quote
cool , thanks alot Thumbs Up Smile
1992nsr125rk ..
DynamiteBoy
PostPosted: 19:02 - 05 Feb 2006    Post subject: Reply with quote
Don't mean to be too cheeky but would you also know the standard settings for the pilot screw on a Honda CG125 carb, its an 'L' plate (94). If not then can anyone point me the right direction...cheers, Ow
alains
PostPosted: 19:14 - 05 Feb 2006    Post subject: Reply with quote
on four strokes you ears are the best thing for settings . adjust where you hear your engine running smooth by playing with the pilot screw (it could be around this value)
The last post was made 20 years, 190 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.58 - MySQL Queries: 13 - Page Size: 59.92 Kb
