Tempory fix for cracked engine caseing
froggy128
PostPosted: 19:20 - 05 Feb 2006    Post subject: Tempory fix for cracked engine caseing Reply with quote
Anyone know of a tempory fix theres a small crack in engine caseing drips only when on side stand but its going to be a few days till i can get a new case what can i use for now?
White Noise
Mr Dudwee
PostPosted: 19:24 - 05 Feb 2006    Post subject: Reply with quote
plug it with epoxy resin?
can't thing that a type of sealent would be hard waring enough in that location
WN
froggy128
PostPosted: 19:39 - 05 Feb 2006    Post subject: Reply with quote
if i kept it toped up with oil would it do much damage. As its not dripping out fast and not at all when its stood straight and rideing just whens its on it side stand.
mr.z
PostPosted: 19:45 - 05 Feb 2006    Post subject: Reply with quote
Chemical metal, (dunno if thats the same as epoxy resin? think it might be) they use it to make temorary repairs to ships hulls! so if it works there then i'm sure it will be ok for your engine caseing...
Out of interest where on the case is it cracked? you might be able to repair it and flog it on...
Otherwise, if its not peeing it out then just keep an eye on the level and ignore it for a while, provided it dosn't start comeing out faster its perfectly fine, just be very carefull the level stays where it should be...
PostPosted: 19:50 - 05 Feb 2006    Post subject: Reply with quote
JB weld will do it. Amazing stuff Thumbs Up Degrerase the area well first.
The last post was made 20 years, 135 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.41 - MySQL Queries: 13 - Page Size: 43.54 Kb
