| MikeH |
 MikeH Brolly Dolly
 Posted: 23:04 - 06 Feb 2006 Post subject: Big Trailie Handling |
Today is the first really dry day we've had for ages and as I finished work early it's the first day I've been able to ride home in daylight so thought I'd give the KLE a bit of a push to see how she'd go on some quick twisty A road stuff.
OK so I know it's no sports bike, but I expected it to handle reasonabley well, but shit me it doesn't half feel light at 80+, the slightest little bump in the road and it's all over the shop, it really feels loose and unpredictable when your leaning into the corners.
I've checked the tyre pressures and they're spot on, the rear shock is on the middle setting which as I bought it from the previous chap, and there's no sign of any play in the suspension or axles. The only thing I did notice is the rear tyre is pretty well squared off , the centre of the tread is down to about 2 - 3 mm while the outer 1" is pretty much untouched.
.......any suggestions to improve things...........other than pxing it for a Gixxer
Mike ____________________ Busa Junkie |
| cagiva gezzer |
 cagiva gezzer World Chat Champion
| G |
 G The Voice of Reason
| syris |
 syris Crazy Courier
| mr.z |
 mr.z World Chat Champion
 Posted: 00:44 - 07 Feb 2006 Post subject: |
Um... get a new tyre
Thing that got me most about this kind of bike, rideing it was very easy, too easy.. to the point of being boreing
Your headbearings possibly could do with tightening? really not much else youve not mentioned.. tyres would be the first thing, they can do some pretty weird things when there worn Might eb woth checking the brakes aren't binding at all? (can induce wobble) and that all engine mounting bolts are tightened up propperly..
Stinkwheel has a kle i think, should be able to give some insight  ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| cagiva gezzer |
| stinkwheel |
 Posted: 10:38 - 07 Feb 2006 Post subject: |
Aye, but stinkwheel has 17" cast alloy wheels in his KLE .
What sort of tyres do you have in it? 21" Knobbly ones can get a bit wishy-washy at speed and a square rear won't help matters.
Mine did what you describe when I first got it with a HORRIBLY worn front tyre (original 10 year old front tyre with 6,500 miles of wear on it) nae good. A replacement settled it down a lot.
You do get more road-biased tyres. Pretty sure you can now get avon distanzias in 21" which are a nice 'compromise' tyre (they commonly fit them to BMWs). ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| mchaggis |
 mchaggis World Chat Champion
| quacker_boy |
 quacker_boy Cuddle Bitch
| MikeH |
 MikeH Brolly Dolly
 Posted: 23:18 - 07 Feb 2006 Post subject: |
It's got Pirelli (road tyres) on front and rear, the front has loads of tread but the rear is on it's last legs. I have no issues with speed wobble, had it upto 110 on the M'way today and although it's a bit hairy and you need neck muscles like Arnie unless you lie on the tank it's basically OK in a straight line. It's just cornering on not so smooth A roads that it seems to go a bit Pete Tong.
I'll back off the rear spring setting at the weekend and have a look at the head bearings, best start saving for a new tyre too I suppose.
Cheers for the feedback guys  ____________________ Busa Junkie |
| syris |
 syris Crazy Courier
 Posted: 00:40 - 08 Feb 2006 Post subject: |
Is it a pirelli scorpion MT? I had a MT90 on the back of mine which didn't help things - not alot of grip, but it lasted about a 1000 miles more than any of the other tyre makes I had on it. I had 4 back tyres on the bike in the same time I had the same one on the front , when I sold it. |
| MikeH |
 MikeH Brolly Dolly
| syris |
 syris Crazy Courier
| MikeH |
 MikeH Brolly Dolly
| syris |
 syris Crazy Courier
 Posted: 01:17 - 08 Feb 2006 Post subject: |
I had a 17" 120/90 on the back (I think) can't remember the front. Although I think you could have put a 130 on the rear. The right tyre on trail bikes makes a hell of a difference, just try different ones - doesn't take long to wear them out anyway  |
| stinkwheel |
 Posted: 01:56 - 08 Feb 2006 Post subject: |
I just wonder if it is the 'normal' boingy suspension type handling you are experiencing.
I remember when I first got my MZ, it felt like I was going to go over the handlebars at any minute whenever I touched the brakes (in reality, the back wheel lifts slightly if you push really hard). They do tend to wallow about a bit more than a sports bike, you are more floating on top of the wheels than pressing down on them.
Needs a looser hand than a sports bike, you kind of roll your hips to one side, let it point itself in the direction you want to go and allow the suspension soak up the difference. You also get used to sort of pushing the front-end down as you enter a corner, the saddle is designed for you to move about a lot on, get sat well forwards on it (almost on the 'up' bit at the front) if you are pushing hard through corners.
Difficult to describe what I find myself doing, it is almost as if I turn the bike slightly away from the corner before the turn-in point then almost 'bounce' the bike back over the top to lean in, so the suspension is compressed. It may help if you say 'boing' in your head as you do so? (that sounds really stupid, I know) ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| lilredmachine |
 lilredmachine World Chat Champion
| Valver |
 Valver World Chat Champion
| MikeH |
 MikeH Brolly Dolly
 Posted: 23:59 - 08 Feb 2006 Post subject: |
Cheers fellas, I'll try it out.  ____________________ Busa Junkie |
| MikeH |
 MikeH Brolly Dolly
 Posted: 20:29 - 09 Feb 2006 Post subject: |
heh heh, top advice guys
I dropped the rear spring adjuster a notch last night and today I had to go out to a customers site, a 45 mile round trip. Sun shining, roads dry & grippy, cornering was so much better. The combination of shifting my weight forward and better roads makes such a difference, I was taking corners comfortably 80+ one long sweeper I took at 90 and it was solid as a rock all the way round not a hint of he wishy washy feeling I had the other day.
Happy Days (and slimmer chicken strips)  ____________________ Busa Junkie |
| MikeH |
 MikeH Brolly Dolly
 Posted: 18:49 - 05 Mar 2006 Post subject: |
Quick update, I had a new Bridgestone Trailwing rear tyre fitted yesterday and I've been out and about today putting some miles on it. The bikes behaviour has been transformed, I can lean with much more confidence now, it feels totally planted even on todays cold damp roads. I'm well impressed with the change it's made.
Looking at it now the old tyre was well squared compared to the new one no wonder it handled like a three legged pig !  ____________________ Busa Junkie |
The last post was made 20 years, 208 days ago. Instead of replying here, would creating a new thread be more useful? |
