Torque wrenches
nrml76
PostPosted: 18:30 - 04 Feb 2006    Post subject: Torque wrenches Reply with quote
Any advice on what type to buy, brands to avoid, useful accessories etc? Any do's or dont's while using them?
mchaggis
PostPosted: 19:24 - 04 Feb 2006    Post subject: Reply with quote
The halfords professional ones have a good reputation I think. Make sure the threads are clean and don't put it away with the wrench wound up to a high torque, it knocks them right out of whack. Also use good sockets (preferably six sided rather than twelve) to reduce the risk of nut/ boltheads slipping/ rounding, leading to inevitable bloody knuckles and damaged equipment. A 3/8" drive wrench should cover (most of) what you need to tighten.* A decent socket set is also a necessity really too.
The only things I have seen which my torque wrench isn't rated high enough for is the rear wheel centre nut on a scooter, and the rotor bolt on the alternator.
I must not be a troll...
Mmmm, Guinness
syl
PostPosted: 19:44 - 04 Feb 2006    Post subject: Reply with quote
I was looking at buying one of those (got myself a Halfords pro socket set at Christmas). Unfortunately, one just won't do it. Torque settings vary from 0.2 Nm to 135 Nm. Their 8-60 Nm wrench would cover most stuff, but not the rear axle bolt which is probably the one that will be loosened most often. Sad
Current bike: Kawasaki Z750S
mchaggis
PostPosted: 00:45 - 05 Feb 2006    Post subject: Reply with quote
For something as large and highly torqued as an axle bolt, it can be difficult to put enough force on a torque wrench to get it to click anyway. Instead I just put most of my weight on the end of a large spanner or an extended socket wrench. I have only had one loose wheel incident, and that was the time I only tightened it wrist tight. Doh! Brick Wall
Mmmm, Guinness
satans_BIG_helper
PostPosted: 00:47 - 05 Feb 2006    Post subject: Reply with quote
i spent £25 on one from argos and it has never let me down and so far has covered every setting i have needed Cool (to date)
mr.z
PostPosted: 00:59 - 05 Feb 2006    Post subject: Reply with quote
Another vote for the halfords one..
The cheap ones dont last as long as the springs go off, so what you think is 10lbft soon becomes 15, the 20 then snaaaap! Sad some are ok, but its hard to tell, some are really very bad..
£50 allot but think of it as an investment, a decent one will last years and years.. i reckon mine will be fine in ten years time...
jamieclayton9
PostPosted: 16:31 - 06 Feb 2006    Post subject: Reply with quote
hi there. i get mine from argos. to be fair it aint the best qulity but better than alot of other cheap ones i have brought. i have had it for 12 months and it has been fine. it is a half inch drive one and it is only £15. cheers. jamie
all my previous rides, c50 steppie, h100s, cb250n superdream, gpz500s, gsf600s bandit, gsf1200s bandit, zx6r, thunderace, dr350, sv650s, cb600f hornet ooohhhhh and the mrs
kawakid
PostPosted: 14:43 - 07 Feb 2006    Post subject: Reply with quote
Same as me, it's not as if I am a full time mechanic, it does the job.
I've a twin and a 4.
numark1
Scared of girls
PostPosted: 15:18 - 07 Feb 2006    Post subject: Reply with quote
T-Bar and a mallet does me. Cool
Haven't had any wheels/swingarms fall off yet. Thumbs Up
The last post was made 19 years, 364 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.55 - MySQL Queries: 15 - Page Size: 62.04 Kb
