| ppeaster |
 ppeaster Borekit Bruiser
 Posted: 10:12 - 05 Feb 2006 Post subject: Thundercat - Can't Read Oil Level! |
About a week ago, armed with a Haynes manual, I carried out my first oil + oil filter change on the thundercat.
When I added the new oil I measured out the required amount (2.9 litres).
Yesterday I went for a ride and the oil light came on twice - both very briefly when under hard acceleration at low revs. After the second time I took it easy and came home.
I took this to mean the oil level was too low, so last night I sat on the bike whilst girlfriend checked the oil level. She says she couldn't see any oil in it, so I added more (just over half a litre) but she still couldn't see any oil in the level! The bike had been warmed up.
I didn't add any more because the handbook says the full capacity is only 3.5 litres.
Basically can anyone give me a steer on the best approach? Am I OK to add more and hope the level eventually raises up? Or is there too much oil in it so the level's already too high? I doubt this is the case because I don't think it would cause the oil light to come on whilst riding. But I am no expert.
Any advice appreciated.  |
| satans_BIG_helper |
 satans_BIG_helper Nearly there...
 Posted: 18:35 - 06 Feb 2006 Post subject: |
May sound like a silly reply but did you put the oil drain plug back in properly ? or maybe the seal on it is leaking or even the oil filter is leaking ?
Quite possibly tho u underfilled if u changed the filter ?
| bish777 |
 bish777 World Chat Champion
| veeeffarr |
 veeeffarr Super Spammer
 Posted: 23:29 - 06 Feb 2006 Post subject: |
If you're checking it while it is warm the oil is still going to be in the engine isn't it.
| Rob W |
 Rob W World Chat Champion
 Posted: 09:53 - 07 Feb 2006 Post subject: |
https://www.bikechatforums.com/viewtopic.php?t=73656
Why did you post the thread twice when you already had answers there? ____________________ TS50 > Senda 125 > ZXR400 > CB-1 > GSX-R1000 > Bandit 600 > ZXR750 H1 > GSX-R750 SRAD > '98 RR-W Fireblade > T595 Daytona > Hornet 900 > '04 Fireblade > GSX-S1000F (x2) > '23 XSR900 |
| feef |
 feef Energiser Bunny
 Posted: 14:35 - 07 Feb 2006 Post subject: |
thunderace is the same.. it's a pig to see the oil level thru the sightglass...
if you overfill it, you'll probbaly get a sticky/notchy gear change and find neutral hard to get into, and oil in your airbox from the vent.
too much oil can also blow seals.
the oil light in the 'ace comes on all the time, hot or cold.. and usually goes away again pretty quick. It's lying thru it's little luminous teeth
you've measured out the right amount of oil.. it's running and not leaving a slick behind you, I reckon you're safe.
a ____________________ Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating |
| bish777 |
| faith183uk |
 faith183uk Nitrous Nuisance
The last post was made 20 years, 2 days ago. Instead of replying here, would creating a new thread be more useful? |
