| DanceLikeAMon... |
 DanceLikeAMon... World Chat Champion
 Posted: 12:42 - 09 Feb 2006 Post subject: 'Leccy problems - Possible solution?!?!?!? |
This one has got me stumped, answers on a postcard please
One of my twin headlamps blew.
Took out the battery to charge it while I waited for a new bulb.
Washed bike without seat on (a clue here in that I may have got water on the wiring/fuses etc)
Put new bulb in.
Put freshly charge battery in (I checked and it was at 12.7(ish) volts.
Bike and bulb worked fine - went out for spin.
Next day, turned key and got nothing, no lights no power at all.
Took out fuse, and put same fuse straight back in - got power, bike worked fine.
Next day, while riding the bike the indicators started doing the fast blink as if the reg/rec wasn't working.
Went out this morning to see if I can find where the fault is, turned the key to start it up, but got absolutely nothing again.
Took out the fuse again, put it back in - got power, but got the speedy indicators again (although the battery was running at 13.1v - so it is charging). Had to go into work at this point, but five minutes into the ride (ie when the bike was warmed up) the indicators went to normal speed and everything was fine.
Anyone got any clues at to what's going on? It was about -5 C this morning, so could it be the cold causing electrical problems?
Ta for any advice.
Ooh, one other thing, I coated everything with WD40 this morning (including the connectors) to try and keep the damp out - is there any product available that's better?
| stinkwheel |
 Posted: 12:55 - 09 Feb 2006 Post subject: |
Is the main fuse on the starter solenoid? This type are very prone to corrosion round the terminals and even tracking back up the wire which can lead to inermittant contacts.
Also make sure the contacts have a good 'grip' of the tags on the fuse, they sometimes need a wee bit of a tighten up with a pair of needle nose pliers.
WD40 is as good as anything for getting the water out of electricals, that is its primary function. "WD" stands for "Water Displacing". ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| DanceLikeAMon... |
| Guest |
 Guest Brolly Dolly
 Posted: 17:53 - 09 Feb 2006 Post subject: |
What Stinky says, it sounds like a loose fuse and/or a bit of water ingress.
Give the area a thorough clean up, fuse holders can hold water too. A few minutes with a hair dryer wouldn't hurt it either. Then douse with WD 40
If you can't get at the bit the fuse pushes into to squeeze the tabs up, gently bend the tabs on the fuse (assuming it's one like this)
https://static.howstuffworks.com/gif/wfc-fuse-blown.jpg
away from each other - only a smidgeon mind  |
| DanceLikeAMon... |
 Posted: 19:20 - 09 Feb 2006 Post subject: |
Cheers for that.
I have spent the last 2 hours outside freezing my balls off looking at this and the plot is thickening...
There is definitely a poor connection somewhere near the fuse, but I have yet to track it down. The weird thing now is that when the bike is idiling it is producing about 12.9 volts and if I put the indicators on the voltage drops to about 12.8 and they flash normally.
If I rev the bike up the voltage goes up to 13.1 which is fine, but if I keep it revving and put on the indicator it drops right down to 12.4v and the lights blink like heckfire again.
Going to see if I can find me an auto-electrician to have a look-see. I reckon it'll take someone with more skill than me a few minutes to diagnose and fix (I hope). |
| DanceLikeAMon... |
| Dazbo666 |
 Dazbo666 World Chat Champion
 Posted: 21:25 - 11 Feb 2006 Post subject: |
Had a similar problem with my car just before I sold it last month.
Would advise checking or replacing the fuse, and also check the regulator or relay on the lighting circuit.
Apparently it was a knackered regulator on my car... when it starts to fail it'll get noticeably warm to the touch, and also cause the indicators to flash at least double speed.
HTH ____________________ 1st bike (Sept'06 - May'10) : 1991 GPZ500S / Current bike (since Nov 2009) : 2003 Suzuki Bandit 600N
Word of the day : DILLIGAF |
| DanceLikeAMon... |
The last post was made 20 years, 243 days ago. Instead of replying here, would creating a new thread be more useful? |
