CG125 Clutch
DynamiteBoy
PostPosted: 18:20 - 09 Feb 2006    Post subject: CG125 Clutch Reply with quote
Alright Guys, Having a bit of problems adjusting my clutch cable on CG.
After following up suggestions for why my bike stalled at junctions i have found that the back wheel always spins with clutch in while in gear, engine makes a funny noise and stalls if i try and stop the rear wheel from spinning with the clucth engaged. So im guessing that the clutch never fully engages.
If anyone has had similar issue's or have any suggestions i would be grateful for help so i can get back on the road...
veeeffarr
PostPosted: 18:27 - 09 Feb 2006    Post subject: Reply with quote
Even with the clutch held in the wheel should move.
It shouldn't put up a fight when you try and stop the wheel though.
Peel back the rubber cover on your clutch lever, Loosen the circular disc, this is your locknut, twist the grooved barrel until there's less free play in the lever. This is how you perform minor adjustment.
If that isn't working, you'll see two screws connecting the clutch cable to the engine (Along with a 2 inch piece of metal that moves when you pull the clutch in. Loose the locknut and adjust the nut until there's less free play in the clutch. This is how you perform major adjustment.
veeeffarr
PostPosted: 18:28 - 09 Feb 2006    Post subject: Reply with quote
If this is unclear to you I have a service manual to take photographs from when I get home.
(In about 2 hours).
DynamiteBoy
PostPosted: 18:40 - 09 Feb 2006    Post subject: Reply with quote
Cheers for the quick reply Toby...the back does put up a fight if i try to stop it from spinning. Not sure what manual u got but i got a hanyes for the bike knocking about, ill have a look at it in more detail 2nite and have an attempt at adjusting the cable at the engine (major adjustment) tomorrow when i finish work, early on a fri...
The last post was made 20 years, 258 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 38.93 Kb
