| curryfishball |
 curryfishball Nova Slayer
| alains |
 alains World Chat Champion
| curryfishball |
| alains |
| Teaman |
 Teaman World Chat Champion
| Guest |
 Guest Brolly Dolly
| curryfishball |
| alains |
 Posted: 23:17 - 05 Feb 2006 Post subject: |
i hope will hane no surprise  ____________________ the worst day fishing is better than the best day working |
| Superlight |
 Superlight Nitrous Nuisance
| alains |
| curryfishball |
| Superlight |
| mchaggis |
 mchaggis World Chat Champion
 Posted: 21:43 - 09 Feb 2006 Post subject: |
I hate to be a smartarse, but the air gap in the switch will conduct if you put a big enough potential across it to ionise it. Air has a resistance, just a whacking big one, so the current across it is effectively zero. ____________________ I must not be a troll...
Mmmm, Guinness
| sickpup |
 sickpup Old Timer
| alains |
| sickpup |
 sickpup Old Timer
 Posted: 23:01 - 09 Feb 2006 Post subject: |
Regulaters can also be faulty.
I understand you are just being safe.  |
| True Blue |
 True Blue World Chat Champion
| alains |
| True Blue |
| alains |
 Posted: 00:02 - 10 Feb 2006 Post subject: |
yes indeed  ____________________ the worst day fishing is better than the best day working |
| mchaggis |
 Posted: 02:24 - 10 Feb 2006 Post subject: |
Plain, bog standard air itself is fairly inert, especially if it is bone dry. However, damp air has a lot of ions suspended in it (water droplets, H+ and OH-) which will conduct electricity perfectly well. If you apply a high enough electric potential to air, especially damp air, you can give the molecules enough energy to ionise and become capable of conducting a current.
That is what happens with lightning and is the basis of any electrical spark producing system (i.e. spark plug). Batteries discharge over time as the H+ ions react with the air to become water, and metals undergo galvanic corrosion because air contains moisture so can act as an electrolyte connecting anodic and cathodic regions of the metal caused by impurities.
It's an interesting thing is rust. I found a fairly good description of the process in a pdf of a Specifier's Guide to galvanisation taken from the American Galvanizers Association: ____________________ I must not be a troll...
Mmmm, Guinness
| Guest |
 Guest Brolly Dolly
 Posted: 07:41 - 10 Feb 2006 Post subject: |
Air is a pretty good insulator if it's dry - I work on the high voltage system and we use air break isloator switches either side of the equipment we have to work on - these give a gap of around 3 ft. for 33000 volts and 8ft for 132000 volts. This is enough to stop us getting killed while working
On a 12 volt system the gap can be almost nothing. If you were pushing enough voltage and current to jump the gap then the wires would have melted first.
on a typical bike's electrical system you have a circuit that goes battery-main fuse-ignition switch-fuse box-other circuits like lights, ignition, indicators etc.
So if you connect a charger across the battery while it's still connected you're only pushing juice as far as the open ignition switch - nowhere near any other components |
| True Blue |
| True Blue |
| True Blue |
 Posted: 08:53 - 10 Feb 2006 Post subject: |
Anyway, back to the point. It won't do any damage connecting a charger to your electrics. As long as it's connected to the battery. I fit chargers to engines almost everyday in my job and some of them have been running for over 40 years with no problems.  ____________________ Past >>>> Honda NSR 125 >>>> Suzuki GSXR 600 K1 >>>> Suzuki GSXR 600 K4 >>>>Kawasaki Z1000 DAF >>>>Suzuki RMZ 250 >>>> Current >>>> KTM Superduke R 1290 >>>> |
The last post was made 20 years, 245 days ago. Instead of replying here, would creating a new thread be more useful? |
