Cheap dustcap warning
shammon
PostPosted: 21:49 - 09 Feb 2006    Post subject: Cheap dustcap warning Reply with quote
Cheap dust cap covers seem great as we know dust caps can often get stolen. but im going to stick with the good old black basic ones after putting on a cheap set...THEY JAMMED. The buggers after 2 weeks seemed to disintergrate inside and as i turned them to remove no joy i had to use plyers and then the dam valve started to turn Evil or Very Mad
Good old WD40 saved the day and helped loosen it, So be warned.
https://i7.photobucket.com/albums/y277/shammon/ffs.jpg
YAMAHA YZF 1000cc THUNDERACE- 'ƃuıןןǝds ʇnoqɐ ʇıɥs ɐ ǝʌıƃ ʇuop ı
Ichy
PostPosted: 22:16 - 09 Feb 2006    Post subject: Reply with quote
Looks like it had started to corrode, different materials can react chemically when put together. If you want to use them its worth putting a bit of copper grease on the thread, might stop them sticking.
RickHolt
PostPosted: 01:07 - 10 Feb 2006    Post subject: Reply with quote
Or just normal grease, cheaper. Unless there's a reason for you needing the copper in this situation? Can't think of one.
I was a bit suprised to see how much copper grease has been used on my new bike. It's on things like the fairing and starter motor bolts.
It is for use in high heat areas where normal grease can't cope isn't it?
Jrod
Page 3 Girl
PostPosted: 13:53 - 10 Feb 2006    Post subject: Reply with quote
I use anodised purple ones (obviously) and just put a bit of copper slip on the thread before I put them on and they havn't siezed. Thumbs Up
Richard1987
PostPosted: 16:43 - 10 Feb 2006    Post subject: Reply with quote
i got some cheap flashing red ones, all plastic so it wont corrode Razz
Cant tighten them too much. they snap very easy Sad but at £1 for a pair who cares . poundland Mr. Green
add me to your msn messenger contacts : [email protected]
Ichy
PostPosted: 19:56 - 10 Feb 2006    Post subject: Reply with quote
Because copper is an antioxidants, therefore it reduces the risk of corrosion. Normal grease is just a lubricant, no reason why you can't use it but it only stops corrosion if it completely covers the surface.
Copper ( or zinc, aluminium or hybrid) grease is heavy used where dissimilar materials are involved, particulary if there is any form of electrical current such as an earthed bike frame. But like you said normal grease is cheaper.
shammon
PostPosted: 21:36 - 10 Feb 2006    Post subject: Reply with quote
Thanks Guys Thumbs Up
The last post was made 20 years, 244 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 51.97 Kb
