Broken Metacarpals
ali-b
PostPosted: 16:19 - 11 Feb 2006    Post subject: Broken Metacarpals Reply with quote
I have 3 broken metacarpals, the ones that run down the back of the hand, connecting the wrist to the first knuckle joint.
Now, depending on who you ask (doctors, physiologists, physiotherapists, google etc etc) it takes somewhere between 4 weeks and 3 months to heal up. The fracture clinic is taking the slab off this thursday and didn't actually say they were putting anything else back on.
Now, my actual question is...has anyone had broken metacarpals and how long did they take to heal?
Cheers,
A.
BanditBitch
PostPosted: 16:29 - 11 Feb 2006    Post subject: Reply with quote
I am presuming you have a back slab on, (half a pot), which they put on to allow the swelling to go down,before they apply a full plaster.
So they will more than like put some sort of full plaster on, when you go back, providing the swelling has gone down.
Skunkcap Freddie
PostPosted: 16:31 - 11 Feb 2006    Post subject: Reply with quote
i broke one on my right hand, the one that connects to the smallest finger. it was clean break.
it took 3 weeks to join together again. it was still badly cracked, but i was fed up with a cast. so i went without one. it was painful to put pressure on my right hand for nearly a year afterwards. and was quite a long time before it didn't hurt when i wacked it /punched somthing/someone
ali-b
PostPosted: 16:34 - 11 Feb 2006    Post subject: Reply with quote
hi,
I had a back slab on, which they took off last week and replaced with a fibreglass slab on the underside which pushed my wrist back and held my fingers (sort of) straight (the name of the slab began with V, but i couldn't read the rest of it)
They just said that this one would come off next time. I just wouldn't have thought that the bones could heal in such a short space of time.
A.
Skunkcap Freddie
PostPosted: 16:36 - 11 Feb 2006    Post subject: Reply with quote
they do heal quickly. but its gonna be right and sore for a while to come
Motkram
PostPosted: 16:45 - 11 Feb 2006    Post subject: Reply with quote
I bust one in my thumb as in the piccie; I was in plaster for ages.
Arrow They first tried to hold my thumb in place with the cast, one week on I went for a check up and was told that it was not healing correctly, and suggested surgery.
Arrow Surgery done and thumb wired in place- four weeks in a cast
Arrow Wires removed (with pliers, I shit you not)- two more weeks in a lightweight cast.
Part-time GSXR1000 pilot>Micron Serpert system+K&N, PC111, Sigma slipper clutch, Brembo m/c+Galfer discs, Gilles rearsets, Translogic Quickshifter.
GP125>GSF400>VFR400NC30>YZF600R>YZFR1(1998)+KLR250>YZFR1(2003)>CBR900RRY>YZFR1(2002)>GSXR1000K1+RGV250
ali-b
PostPosted: 16:46 - 11 Feb 2006    Post subject: Reply with quote
I must admit I'm getting really quite fed up of having no right hand, so in one way, I'd kinda like having no replacement cast. Having caught my fingers several times over the last couple of weeks, however, means I'm a bit nervous of going without 'armour' of some kind...
A.
WildGoose
White Van Man
PostPosted: 17:55 - 11 Feb 2006    Post subject: Reply with quote
i broke my fifth, in a bike accident
never had a cast, just like a supporting splint thing
healed quickly, but they broke it again to try and manouvre it straight but failed Confused
hurt for a good year afterwards to put pressure on or make a fist
got a bump in my hand where it hasnt healed straight and a lump on my palm that is uncomfortable to put pressure on due to the bone at a weird angle
swampy
PostPosted: 18:17 - 11 Feb 2006    Post subject: Reply with quote
I broke one in my left hand a couple of years ago falling down some stairs. Mine was pretty much pain free within a month, looking at some of the other replies here I was quite lucky.. Thumbs Up
nrml76
PostPosted: 16:46 - 12 Feb 2006    Post subject: Reply with quote
You have 5 metacarpals, which all act as natural splints for each other. If the fracture starts healing and is no longer mobile, the slab/splint can come off.
Nath
PostPosted: 17:06 - 12 Feb 2006    Post subject: Reply with quote
Broke the one for my little finger, due to punching a window Embarassed (I have a nasty tendency to hook my punches)
Didn't bother going to the doctors, just let it heal on its own. Probably took about 2 weeks till I was able to grip things normally, but took well over a month for the mend to stop being sore. Because I didn't go to hospital to have it set properly, the two sides of the bone both protrude up creating a weird lump, and the knuckle is lower than it should be due to the bone being angled down.
That was the second time I broke that bone. I did a similar injury six months earlier, from punching a window exactly the same Embarassed However that time it must only have been a fracture as I couldn't wiggle the bone around, and because it looked pretty normal after the swelling went down.
Hard livin', hard luck.
syl
PostPosted: 22:15 - 12 Feb 2006    Post subject: Re: Broken Metacarpals Reply with quote
Cheers,
A.
Just the 5th metacarpal and you may have got away with bandaging a couple of fingers together. I suspect you're looking at 4-6 weeks in a cast.
Current bike: Kawasaki Z750S
ali-b
PostPosted: 11:57 - 13 Feb 2006    Post subject: Reply with quote
I thought you had lots of metacarpals, like every bone in your hand is one and they just number them. I broke (I think) 13, 14 and 15???
No splinting together unfortunately as they're in my hand not my fingers. So I guess another couple of weeks in my cast Sad
On the plus side, I've managed to straighten my fingers out (the tendons had seized up curled) with lollypop sticks and cable ties Smile
I feel quite lucky that I didn't have to have pins from those pictures Smile
And embarassingly, my fingers stink!
A.
Skunkcap Freddie
PostPosted: 12:53 - 13 Feb 2006    Post subject: Reply with quote
lol. stinky knuckles.
were've i heard that before
syl
PostPosted: 13:15 - 13 Feb 2006    Post subject: Reply with quote
You've got 5 metacarpals in each hand. Number 1 is the one under your thumb.
https://www.davidlnelson.md/images/hand_anatomy_bones.jpg
Flip
PostPosted: 13:17 - 13 Feb 2006    Post subject: Reply with quote
Broke loads of them. Laughing Takes a few weeks.
The last post was made 19 years, 310 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 89.74 Kb
