Soldering Q + Autocom mobile adaptor Q
DukeRed
PostPosted: 19:07 - 11 Feb 2006    Post subject: Soldering Q + Autocom mobile adaptor Q Reply with quote
I'm modifying the garmin car charger to work with an audio jack and wired in to the bike.
Problem is both the wires for power came off the circuit board. Now can I just solder them back on or is there a special factory process? Will I damage the board, there is a tiny little box next to where I need to solder and since I'm cack handed with a solderer that's probably going to get covered in the blob.
Any other methods?
Enjoy Life There's Plenty of Time to be Dead
https://www.janoner.com
nrml76
PostPosted: 19:20 - 11 Feb 2006    Post subject: Reply with quote
Just apply the hot iron to remove all traces of the old solder / wire remains. One of those suction solder removal things might be handy. Thread the new wire through the hole on the board and apply a tiny blob of fresh solder from the bottom. Dont be afraid of the solder spreading. Use small quantities, and if worst comes to worst, you can reheat and remove. Avoid prolonged heating of the board components. When doing my garmin, I replaced the fuse with a bike fuse in a weather proof housing. It made hard wiring much easier.
DukeRed
PostPosted: 19:27 - 11 Feb 2006    Post subject: Reply with quote
Would I still have to fuse it if I'm wiring it in to the clocks since they already have a fuse? If I do what size proper fuse instead of glass?
-Savage-
PostPosted: 19:41 - 11 Feb 2006    Post subject: Reply with quote
what we used to do was to connect crocadile clips or similar heat sink type thing, to the other side of the board, so it soaks up any excess heat for you
nrml76
PostPosted: 20:01 - 11 Feb 2006    Post subject: Reply with quote
A seperate fuse would be additional protection from current surges or short circuits. I cant remember what I put in, but I can have a look in the morning. Alternatively, check with garmin for the current rating of the fuse they put into the cigar lighter adapter and use something similar.
DukeRed
PostPosted: 21:49 - 11 Feb 2006    Post subject: Reply with quote
Another thing, Which way round would I wire up a phono jack for a mobile phone adaptor. The intention is to butcher a hands free kit so I can use on the autocom.
owdamer
PostPosted: 12:06 - 12 Feb 2006    Post subject: Reply with quote
Best way to clean off the old solder is with copper braid. Just put the brain onto the solder, press down with your iron & the brain will soak the old solder up like a sponge.
The last post was made 20 years, 241 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 52.14 Kb
