Stand up Wheelies............
Jewell This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
owdamer
PostPosted: 09:39 - 12 Feb 2006    Post subject: Reply with quote
Stand up wheelies? Pah! how about this?
https://stunt.ca/forum/pics_tricks/apehanger.jpg
PostPosted: 10:02 - 12 Feb 2006    Post subject: Re: Stand up Wheelies............ Reply with quote
Can you clutch it up normally?
For stand ups I clutch it up sitting down.
I then stand up.
If I'm using the left pillion peg I will usually clutch it up with my foot already on it, however I do sometimes start with my left foot on the rider footpegs if I want to change gear, then move my foot back to the pillion peg, then stand up.
Do try and keep your weight back wen doing them; as if you were pusing the bike away from you, otherwise the balance point gets stupidly high. Even holding the bike away from me like this I still found that I was pretty damn high on the TRX often!
Annoyingly the TRX doesn't seem to like balance point wheelies when sitting down as it gets a side to side wobble on before you can get high enough.
Some of my attempts:
https://earboards.com/brooklands.mpg
I did sort out doing proper balance points ones, but unfortunately the camera battery died so didn't get most of my decent ones. I'm on the TRX850 - also me on the zx9, but it wasn't running to well with year old petrol, so couldn't do anything decent.
DukeRed
PostPosted: 11:18 - 12 Feb 2006    Post subject: Reply with quote
How thw hell do you do that on the TRX? Remeber you said 4k, clutch in, throttle, clutch out. Just can't get much lift and scared for my head bearings
I put it down to photoshop. Smile
Enjoy Life There's Plenty of Time to be Dead
https://www.janoner.com
owdamer
PostPosted: 12:20 - 12 Feb 2006    Post subject: Reply with quote
Jewell wrote:
and why would i want to drag my knees?
You could do it to wear down kneesliders which you could then flog on ebay..... Very Happy
fast_tzr
PostPosted: 12:22 - 12 Feb 2006    Post subject: Reply with quote
Just me that finds stand ups easier than sitting down?
PostPosted: 13:26 - 13 Feb 2006    Post subject: Reply with quote
I'm not too sure exactly what revs I use.
But basically, you probably need to rev a bit more dump the clutch faster.
As for the head bearings, the trick is to let it down gently.
If you are holding it steady, dip the throttle, then bring it back on again to about the same point. This should make the front 'float' down; sometimes it's even a case of dipping it then when you've dropped a bit pulling it on even more.
Just shutting off the throttle will see engine braking try to force the front wheel into the tarmac, not such a good thing Smile.
TZR:
Seeing that I can't get to the balance point in sitdown wheelies as the bike wobbles side to side too much, I also find stand up wheelies easier.
bidman
PostPosted: 14:11 - 13 Feb 2006    Post subject: Reply with quote
Nope, I also find stand up wheelies easier than sitting down, i feel more in control of the bike stood up than sat down. I feel i have more control over the front end of the bike. To get the front end up I usualy release the clutch and as the front end starts to come up I stand up and it brings the front up much easier, then play with the throttle to get the balancing point, Thumbs Up Dan
Don't ride it, RAG IT!!
McGee
O RLY?
PostPosted: 14:36 - 13 Feb 2006    Post subject: Reply with quote
Show offs Wink
Sparks is good Thumbs Up
Its pronounced Jixxer!
The last post was made 20 years, 279 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 73.89 Kb
