R6 Hazard lights wont go off.....
fireblade_rrw
PostPosted: 15:55 - 11 Feb 2006    Post subject: R6 Hazard lights wont go off..... Reply with quote
Think its the relay thats seized-up, but at 28 quid its a bitter pill to swallow if it isnt that - does anyone have any ideas? or know where I can get a pattern flasher relay?
R6 2003
Wooly R6
PostPosted: 15:07 - 12 Feb 2006    Post subject: Reply with quote
is the button buggered??
R6 has been sold - 2004 Honda VFR VTEC now sold too - no bike at the moment
Teaman
PostPosted: 15:38 - 12 Feb 2006    Post subject: Reply with quote
if your carefull you can open the relay box up and check, if its buggered it should either be constant off or on,
To me it also sounds like your switch,,
take your switch gear appart and check, spray with wd40
There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them.
Guest
PostPosted: 17:21 - 12 Feb 2006    Post subject: Reply with quote
You'll probably get a replacement relay from a car shop for a fiver - Stinkwheel will know the sort you need I reckon.
But go for the switch first.
fireblade_rrw
PostPosted: 21:39 - 12 Feb 2006    Post subject: Reply with quote
Cheers guys, will try both later this week - if anyone has a link for a cheap(er) R6 flasher relay, would be most appreciated !
I reckon it actually could be the button jammed inside......WD40 next !!!
The last post was made 20 years, 153 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 42.23 Kb
