hydraulic clutch V Conventional
mr.z
PostPosted: 02:04 - 13 Feb 2006    Post subject: hydraulic clutch V Conventional Reply with quote
To anyone whos used both..
Is it much better? smoother? lighter?*
Say if you could retrofit it fairly easyly would it make a big improvement.. appart from the not worrying about the cable pinging off what are the advantages?
Also while its up... are stiffer clutch springs worth it? would a hydraulic clutch make any difference in the force needed to pull the lever?
Thanks for reading Wink
*Can't see it would be but hey might well be...
Visitor Q
$25 whore
PostPosted: 02:10 - 13 Feb 2006    Post subject: Reply with quote
bear in mind anything fails you lose your clutch, almost as suddenly as with cable.
I find mine pretty vague and a sod to set up anyway (on the smod though), also apparently they are harder to slip.... i dunno, i can still clutch up the cbr happily, but like i say, it feels quite binary if you know what i mean.
I far prefer the cables i have to admit.
ZRX61
Victor Meldrew
PostPosted: 02:44 - 13 Feb 2006    Post subject: Reply with quote
Hydraulic is WAY better, haven't done a thing to my clutch in 73,300 miles...
AcIdBuRnZ
PostPosted: 02:48 - 13 Feb 2006    Post subject: Reply with quote
But hydraulic is just something else to leak Laughing
Least a cable can be mended at roadside Thumbs Up
mr.z
PostPosted: 02:57 - 13 Feb 2006    Post subject: Reply with quote
Hmm intereting... ignoreing the difference in clutches, how does hydraulic operation help? or do you just mean its not needed the cable adjusting?
There is the fact you can carry a spare clutch cable, but if i was doing something like this i'd get the lot propperly pressure tested (and can't imagine it would be be put under nearly the same huuuge pressure +heat that brakes are)
bonny_ricardo-How do you mean set it up? bleeding it?
(thanks for the replys all)
PostPosted: 09:30 - 13 Feb 2006    Post subject: Reply with quote
With ZRX61 totally. Far prefer hydraulic clutches. Far less likely to strand you in the middle of nowhere and far smoother. Also far lighter than a cable clutch which is more than a few months old (possibly a slight exageration, but cable clutches do rapidly get heavier).
For those who trust their clutch to a cable, how many would trust their brakes to a cable?
ZRX61
Victor Meldrew
PostPosted: 16:11 - 13 Feb 2006    Post subject: Reply with quote
Apparently AcidBurnz would...... Rolling Eyes
PostPosted: 16:23 - 13 Feb 2006    Post subject: Reply with quote
Suppose I should add something to support their life expectancy.
The FZ750 is now 20 years old with ~65000 miles on the clocks. The clutch line, clutch slave cylinder and clutch master cylinder are all original and on on their original seals. All that has been required is bleeding the system very occasionally (and a new lever, as the original clutch lever had worn out at the pivot and become loose and flappy).
Bandit clutch has done 54000 miles in 9 years and again is on the original lines with all original seals.
mr.z
So, if i'm thinking right.. a hydraulic clutch has no extra movment like the cable, so your just pushing dirctly onto it, instead of haveing to take up the cable slack, stretch it, then it operateing it... ?
Been looking at clutch conversion kits, looks like the lever pulls instead of pushes the fluid (like a brake would)*.. the other end connects where the cable is adjusted next to the clutch, with an arm being pulled into what looks very much like the piston affair thats operated by the rear brake pedal on disc braked bikes..
This is a pic of the arm that operates the clutch normally, and the thing thats normally on the rear brake (dont know the propper term), the red arrow is the normal direction of travel and the blue bit is where i was thinking they would attach..
Would that work?
(apologies for length)- Edited just for you zrx61 Wink
*If normal HClutches Push a little piston inside the clutch then the arm at the clutch end could be fliped arround to push instead of pull...
ZRX61
Victor Meldrew
PostPosted: 16:38 - 13 Feb 2006    Post subject: Reply with quote
No, it pushes same as a brake.
mr.z wrote:
(apologies for longness)
The word is "length" Rolling Eyes
mr.z
PostPosted: 16:57 - 13 Feb 2006    Post subject: Reply with quote
Looking at it again i'm not sure what made me think it didn't.. Doh!
https://www.dual-star.com/index2/Images%20JPG/KLR%20650%20Slave%20Cylinder%20Med.jpg
https://www.dual-star.com/index2/Images%20JPG/KLR%20650%20Slave%20Cylinder%20Top%20Med.jpg
This is the kind of thing i'm thinking of.. would it be feasible to use a piston from a rear brake?
All theoretical at the moment, but theres a chance i'll be able to do it for free or at least very cheaply, so its worth thinking about Thumbs Up
McJamweasel
BCF Junkie
PostPosted: 17:00 - 13 Feb 2006    Post subject: Reply with quote
I wouldn't of thought that you'd get enough movement out of a brake piston - besides the fact that they don't return fully.
PostPosted: 17:09 - 13 Feb 2006    Post subject: Reply with quote
Looking at that setup it IS pulling. Think what is happening is that the fluid is pushed in at the end where the thin rod comes out and pushes a piston (connected to that rod) forwards.
Not sure of any other source for such a hydraulic unit. Suspect that it might also have some issues with how long it lasts. Firstly there are extra seals required (2 moving surfaces which need to be sealed), but also the angle that rod goes into the cylinder will change with the position of the lever on the clutch cover (it will go through an arc) which is likely to shorten the life of that seal by quite a bit.
bish777
PostPosted: 17:15 - 13 Feb 2006    Post subject: Reply with quote
My FJ1200 hit 90,000 miles on its original clutch seals. Never needed any attention in the 30,000 miles i did on the thing.
GSXR1100J
instigator
PostPosted: 17:17 - 13 Feb 2006    Post subject: Reply with quote
Prefer cable myself in my experience, the hydraulic clutch can be a bit grabby at times, especially on the yzf750 I found. Which was quite annoying when you trying and make a quick get away and you're hardly going anywhere. Had me out of the seat too on the second day I had it.
mr.z
PostPosted: 17:25 - 13 Feb 2006    Post subject: Reply with quote
https://www.americandirtbike.com/Hymec3.gif
Thanks for that, just found this pic, your spot on it think, the fluid is pushing the piston away..
As for the angle, if it was pulling it could come down dead stright (would only need to fip it arround if it was pushing), would probably modify the bracket holding it on so that it was lined up.. but then operateing it the rod will not be 100% stright as its puled and pushed...
Hmm a shame, thought it might be done the thrifty way.. the only other thing is to have something within the cluch caseing, will have to pilfer it from an existing hydraulic clutch.. seeing as like mcjamweasel pointed out brakes are hammered back into place by the disc so it wouldn't return...
PostPosted: 17:32 - 13 Feb 2006    Post subject: Reply with quote
Thats not a problem with hydraulic clutches, that is just horrible Yamaha clutches. The Bimota and FZ750 are like that (both hydraulic) as is the FZR600 (cable).
Even better, has a load of dirty great clutch springs pushing it back. All the standard hydraulic set ups I have seen have been mounted on the opposite side of the engine to the clutch and push a rod through the gearbox and onto the clutch pressure plate. There are some cable setups that work a similar way (600 Bandit and FZR600 for a start).
Suspect the reason that cable clutches have come back into fashion is that they are slightly lighter and the makers are desperate to shave weight from the spec sheet.
AcIdBuRnZ
PostPosted: 18:57 - 13 Feb 2006    Post subject: Reply with quote
Eh.... did I say anything about brakes? I've read over my post a few times and I cannot see where you made that connection Thinking
Rolling Eyes
mchaggis
PostPosted: 20:17 - 13 Feb 2006    Post subject: Reply with quote
Me, me!
But only because the CG doesn't go very fast to begin with, and the engine braking is almost stronger than the brakes anyway. Laughing
I'll use whichever is on a bike when I buy it, it is hardly the most important thing when choosing a machine. Cables are simpler but sieze, need adjustment and break, hydraulics last forever and are self adjusting. I did feel the clutch on a Fazer was more vague and the biting point more diffficult to find, in a similar way to a disc brake rear being too sensitive for a clumsy size 11 boot, leading to me stalling on hills. That can be overcome quite easily with practise though.
I must not be a troll...
Mmmm, Guinness
The last post was made 20 years, 279 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 113.36 Kb
