| veeeffarr |
 veeeffarr Super Spammer
 Posted: 20:26 - 13 Feb 2006 Post subject: [HELP!] Chain adjustment [HELP!] |
Hi guys,
Got new chain and sprockets today,
Removed the exhaust of my 2001 CG125 to get to the axle nut, found out i don't have the right socket, so going to try and get it to a mech tomorrow.
Only problem is I can lift the chain quite a few inches off of the rear sprocket - So the gubbed one needs adjusting now... Is it safe to adjust it without loosening the wheel nuts? Either that or ride 20 miles on a loose chain.
I dont have anything to check wheel alignment either, not got a plank of wood, will the swingarm notches do?
I need to ride in about an hour, that's why I can't wait
Toby |
| instigator |
 instigator Super Spammer
| Andrewc2oo5zx... |
 Andrewc2oo5zx... Scooby Slapper
| veeeffarr |
| instigator |
 Posted: 20:40 - 13 Feb 2006 Post subject: |
Where abouts did they come from?
Guessing they go against the engine block to stop any gasses escaping?
Sorry about before, slight misunderstanding Personally, I'd go next door and ask him for the correct sized socket.  |
| lllN30lll |
 lllN30lll World Chat Champion
 Posted: 20:41 - 13 Feb 2006 Post subject: |
don't try to adjust it without undoing the axle nuts.
imagine it like somebody holding there arms out in front of them and holding your wheel in there hands, theres no way your gonna be able to move the wheel forwards or backwards in his hands without loosening his hands.
my got that sounded stupid  ____________________ Turbo R1
CRF450R |
| mr.z |
 mr.z World Chat Champion
| lllN30lll |
| instigator |
| veeeffarr |
| 0ni |
 0ni World Chat Champion
| Kickstart |
 Kickstart The Oracle
 Posted: 21:02 - 13 Feb 2006 Post subject: |
Those look like the exhaust collets. There is a "ring" around the exhaust which the mounting bolts go through into the head. Those collects go between the "ring" and the head. As you tighten the mounting bolts up the collects push on a small lip on the end of the exhaust. There should be a gasket (thick crush washer) between the lip on the end of the exhaust and the cylinder head.
You MUST loosen the wheel spindle to adjust the chain.
| veeeffarr |
| instigator |
 Posted: 21:17 - 13 Feb 2006 Post subject: |
| Kickstart |
 Posted: 21:19 - 13 Feb 2006 Post subject: |
Right, see if I can manage to explain this without confusing you!
There almost certainly should be a gasket in the exhaust port. Might well be stuck there.
The gasket goes in there first. Then the end of the exhaust goes in. Hold the exhaust in place and then put the collects around the exhaust, with the lip away from the engine. With those in position put the ring up to the collects and bolt it in place.
| veeeffarr |
| Zimbo |
 Zimbo World Chat Champion
| veeeffarr |
| cagiva gezzer |
 cagiva gezzer World Chat Champion
 Posted: 21:32 - 13 Feb 2006 Post subject: |
https://www.bikechatforums.com/download.php?id=28881
For getting the alignment right, use a tape measure between the swing arm and wheel bolts. ____________________ "because one stroke isnt enough and four strokes waste two" |
| Kickstart |
| cagiva gezzer |
| veeeffarr |
| Nath |
 Nath World Chat Champion
| mchaggis |
 mchaggis World Chat Champion
 Posted: 00:58 - 14 Feb 2006 Post subject: |
If tight, the rear axle is a real pain to get out with the exhaust in the way, as there is no room to swing a hammer. The exhaust on a CG is annoying to remove if you don't like sticking your head underneath the engine to see what you're doing. It would be nice if it were just a bolt to take it from the hangar but the whole thing is one piece.
I have never seen an exhaust gasket fitted to a CG125 or a clone engine, but then I haven't taken the exhausts off all that many different ones. All I know is that all of the exhausts I have ever dealt with haven't had any from the word go and they still don't*. (Hence why my diagram hasn't got one shown).
As far as I remember, the best fitting tool I have found for the rear axle (RHS) is a 11/16" ring spanner. A 17mm spanner just about fits too, and a 19mm on the LHS. It is essential to loosen the rear axle or you will just stretch and eventually snap the adjustment studs. It is easiest to fit a new chain without taking the wheel off, but necessary to take the wheel off to fit a new rear sprocket. Loosen the bolts holding the front sprocket on before you do anything else, as you can just jam the rear wheel to keep it still.
Wheel alignment isn't as critical as people make out. It helps though, you can feel it if it isn't right at the rear, you can do it almost by eye by watching how the chain impinges on the teeth and whether it is being pulling to one side of the sprocket.
At the front you get used to the bars facing 30 degrees to the left while you are going straight ahead, though the headlamp facing 30 degrees to the left at the same time wasn't so helpful, nor was the footpeg pointing backwards.
Sorry I couldn't be of help earlier TobyR, I've been offline while packing up my computer and sorting out another.
*I think that might be because the Chinese bike I bought never had them to begin with and the other Hondas were old enough for them to have been lost while removing the exhaust and then not replaced. ____________________ I must not be a troll...
Mmmm, Guinness
Discovering the delights of Hammerite and a 3/4" brush.  |
| veeeffarr |
 Posted: 15:56 - 14 Feb 2006 Post subject: |
Hi,
Going into garage tomorrow, 19mm didn't fit.
£45 labour
Ouch. |
The last post was made 20 years, 278 days ago. Instead of replying here, would creating a new thread be more useful? |
