Valve Clearances
ash t
PostPosted: 15:38 - 14 Feb 2006    Post subject: Valve Clearances Reply with quote
Hi.
My NC29 needs the valve clearances doing. I have been getting prices from different places and some are cheaper than others.
My question is, can you do a poor job of doing valve clearances?
Im simply asking this because the most expensive place has a good reputation, and the cheapest place is a small quiet shop which does mainly tyres (Bikerz tyres in Stoke on Trent if anyone knows it)
Just some advice really on whether I would be ok going with the cheapest option.
Ash
When You're Starting To Choke, Take Some Pills With Your Coke, Its Hyserical
PostPosted: 16:24 - 14 Feb 2006    Post subject: Reply with quote
It is perfectly possible to screw up doing the valves, but Bikerz should be more than capable of doing the job.
From looking at a CBR400 I suspect it is quite a fiddly and time consuming job. Also note that I think they are shimmed so quite likely that any mechanic will need to do half the job then order the new shims (you might be lucky if the shims are the same as those used on a fairly common UK model).
ash t
PostPosted: 16:25 - 14 Feb 2006    Post subject: Reply with quote
I will get it booked into Bikerz then. Its convenient for me and close to home Thumbs Up
dotti
PostPosted: 20:55 - 14 Feb 2006    Post subject: Reply with quote
Just out of curiosity, how long do you think it would take a mechanic to check the valve clearances, and make the necessary adjustments? I will get my bikes done soon (GN250 and GS500)and am trying to estimate the cost.
Dangerous traffic offences spotted on 50-minute trip: Lost count after 100. Number of traffic cops spotted: One, sitting by a speed-trap camera
fazed
Korn is my hero!
PostPosted: 21:09 - 14 Feb 2006    Post subject: Reply with quote
Couple of hour's I would say, depends on the bike. Smile
gixxer thou K6 , Cbr400 gullarm x 2 , cb400 superhack.
mchaggis
PostPosted: 23:41 - 14 Feb 2006    Post subject: Reply with quote
If it is a locknut adjuster type, it might take up to half an hour to remove anything stopping you from getting to the valve train, then a minute or so per locknut and then up to half an hour putting everything back together again.
If the valves are adjustable by different thickness shims, expect to spend the time taking things to pieces, then 5-10 minutes per valve checking, plus the additional effort to take the camshafts out(?), then time spent replacing the shims with the right thicknesses, then time spent reassembling. Several hours work.
The GN250 and GS500 would hopefully be locknut adjusters rather than shims, so they would fairly straight forward to adjust and there would be little to need to remove to get the head cover off.
I must not be a troll...
Mmmm, Guinness
instigator
PostPosted: 23:46 - 14 Feb 2006    Post subject: Reply with quote
If I were getting it done on a sportsbike, I'd take off the mid fairings. Saves time as it may take them half an hour to do and they'll charge you for it. Wink
deputy
PostPosted: 15:59 - 15 Feb 2006    Post subject: Reply with quote
ash, how much did Bikerz quote, as I could do with mine looking at and haven't got a clue how much it costs and I only live about 10 miles from Stoke.
the grim reaper
PostPosted: 15:42 - 16 Feb 2006    Post subject: Reply with quote
Also bear in mind that, if you have a big-ish engined bike and you ride it to the dealers, the engine will be too hot to touch for a couple of hours.
The labour time for a good mechanic on an in-line 4 is about an hour and a half, double that for a v2 or v4.
Grim
PostPosted: 16:01 - 16 Feb 2006    Post subject: Reply with quote
You've never tried getting at the head of a CBR400 Laughing . Designed to be serviced by children who are still too young to be used chimney sweeps.
Getting the carbs on and off is a pig, and you are going to have to take the radiator off as well.
TOM M
PostPosted: 00:38 - 17 Feb 2006    Post subject: Reply with quote
I had the valve clearences done on my zxr 400 there a few weeks ago. £106 it cost me and its running sweet now Thumbs Up
Now owner of a 1200 Bandit
deputy
PostPosted: 20:30 - 19 Feb 2006    Post subject: Reply with quote
Cheers for that.
Zimbo
PostPosted: 20:33 - 19 Feb 2006    Post subject: Reply with quote
Generally expect to pay £80 - £100 from a reasonable independant bike shop, for a jap IL4.
They usually have to be checked cold, so you need to allow time for the engine to cool completely before checking them.
iCraig
PostPosted: 20:59 - 19 Feb 2006    Post subject: Reply with quote
GS500 is shimmed, but not in the usual sense.
Ichy
PostPosted: 22:18 - 19 Feb 2006    Post subject: Reply with quote
Is it the bike in your avatar? GSXF600? You should be able to do it yourself in less than half a day even if you haven't done it before. Most of the the time is taken up with the stripping down. Its a good time to check the carb balance as well.
The last post was made 20 years, 278 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 86.91 Kb
