WTF
tatters
Exxon Valdez
PostPosted: 00:14 - 16 Feb 2006    Post subject: WTF Reply with quote
Just seen this in a another thread
https://cgi.ebay.co.uk/HONDA-YAMAHA-ETC-ELECTRIC-CDI-BIKE-MOTORBIKE-TURBO_W0QQitemZ8032202807QQcategoryZ25623QQrdZ1QQcmdZViewItem
Would,nt that just make the mixture very lean and seize the bike Confused
(also its a "supercharger" and not a "turbo" right?)
LustyLew
PostPosted: 00:18 - 16 Feb 2006    Post subject: Reply with quote
I thought a 'turbo' did 'something' (very technical term there!) with the exhaust gases, hence turbocharged bikes not having an exhaust can?
hazza
PostPosted: 00:20 - 16 Feb 2006    Post subject: Reply with quote
that wouldnt work on a two stroke it would just push unburnt fuel through the exhaust port....how does that make a 35% power increase....bullshit
DaveH
Shocked 'Tis a bit bizarre!
I am assuming that it is just an electric fan to force more air through the carb, rather than using exhaust gasses! Similar to the ram air effect that some bikes use, I suppose.
Turbos are driven by exhaust gasses and superchargers are mechanically driven, so not sure what that makes this device.
Wonder if anyone has ever used one.
Jack_Cheese
PostPosted: 00:21 - 16 Feb 2006    Post subject: Reply with quote
Turbos use the exhaust gases to drive a compressor, therefore the faster you go, the more power you get. The reason for no can, is that the extra piping required basically means the exhaust comes out in an unusual position, where a can would just be awkward.
And why the hell can i never see the ebay links on this damn forum!?
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
www.125power.com
PostPosted: 00:27 - 16 Feb 2006    Post subject: Reply with quote
judging from the ad there is no form of fuel management if you put more air and not more petrol your bike will ultra lean. This will not seize the engine if boost is activated at higher rpms, instead your engine will fucking detonate Exclamation
For those who not familiar with denotation, it is most commonly a result of pre-ignition, this is where the hot spots in the engine (spark plug, piston crown etc) ignite fuel before the engine actually fires a spark!. In mild cases this will create knocking or piston slap, and as the engine heats up it gets worse and then the piston meets a violent explosion of fuel while it is rising up (either compresion or exhaust stroke) and it has no where to go, it cant go back down the result DETONATION.
Just how it sounds, fucking booooom Exclamation
My eBay Items
SteWhit
PostPosted: 00:30 - 16 Feb 2006    Post subject: Reply with quote
That's not a turbo, it's a CPU fan with a metal case! Notice he doesn't take Paypal. Probably had too many people wanting their cash back when they found out it dont work! Also according to there fitment guild you have to run it with no air box?! Surly that's not exactly advisable without re-jetting?
Are You Serious??
PostPosted: 00:31 - 16 Feb 2006    Post subject: Reply with quote
Looks like a PC fan.
As far as I know, for the 'proper' systems like this; to get a decent enough pressure, you need loads of batteries that get used up pretty quick.
www.125power.com
PostPosted: 00:32 - 16 Feb 2006    Post subject: Reply with quote
I guess it would make a useless peice of crap, it is probably designed to aid swirl (the mixture of petrol and air to create a fine vapour), due to the exact science of swirl, im guessing it would be pretty useless as it claims to cater for too many bikes. Best aid to swirl is well designed ports. simple as.
I'll bet my life it is a more "up-dated" version of the turbonator
My eBay Items
beanington
PostPosted: 00:34 - 16 Feb 2006    Post subject: Reply with quote
ha ha to tru
www.125power.com
PostPosted: 00:44 - 16 Feb 2006    Post subject: Reply with quote
Okay anyone with more tuning experience is more than welcome to step in and correct me but......
To get that fucker to work, you gotta rejet to suit, it will probably run fine from exsisting power on bike (scooter's probs need uprated battery at least). Okay you got all that sorted you can now drive about wasting lot's of petrol (as it wont be mixing properly due to the stupid fan)
You press the boost button and this fan speeds up pushing more air through the engine (if your lucky bike will run bag of shit and die, telling you its not right). So you figure it out and add a system that will inject more petrol just before the carb's mouth to stop it running lean when button is depressed. Now you have a petrol guzzling bike worthy for the drag strip right? wrong you press the button and the amount of fuel and air entering the engine is too much for it to burn effectively leaving your bike with less power and money then when you started, and in debt with shell or BP where ever you decide to get petrol from.
steer well clear, this is another power resistor of justice!
My eBay Items
beanington
PostPosted: 00:46 - 16 Feb 2006    Post subject: Reply with quote
ha ha that sounds about right actualy
JamesVFR This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Jack_Cheese
PostPosted: 00:57 - 16 Feb 2006    Post subject: Reply with quote
seems more likely to inhibit airflow than improve it.
Jack
www.125power.com
PostPosted: 01:02 - 16 Feb 2006    Post subject: Reply with quote
exactly........and if it does work it will over do it anyway
My eBay Items
lilredmachine
PostPosted: 01:10 - 16 Feb 2006    Post subject: Reply with quote
TBH, they use these sorts of things on big trucks, they are designed to increase torque and are called e-chargers (or hybrid turbos) i believe. A proper one can produce incredible power, and more importantly, it is lag free as the fan is kept spinning by the electric motor. A real one is still connected to the exhaust system, the electric motor merely combats lag, so this is not really a proper system at all. As has been stated, this is closer to a cpu fan in a shiny case than a proper e-charger. I should imagine it does provide some improvement, if only for a short time. Before boom.
Both would use the same compressor, but to avoid the lag inherent in turbocharger, an electric motor would be attached to the to the turbocharger for power in those vital five to ten seconds. The electric motor would cut out after the turbocharger achieves full boost
PostPosted: 01:26 - 16 Feb 2006    Post subject: Reply with quote
The amount of electrical power required to drive a fan to produce some decent extra power would be hideous.
Doubt that produces any real boost. Probably a good job. It is blowing through the carb, so would (if it worked) pressurise it. Very good way of running very lean as the float bowl is not pressurised. Instead of drawing fuel out of the float bowl it would likely blow air into the float bowl.
Also no relation to engine speed, just a switch so pretty useless there.
Finally the air filter on it looks pretty hopeless. Pathetic surface area. That would be pretty restrictive.
Anyone fancy buying one to laugh at. Only trouble is it would cost far more in dyno time to show how useless it is.
PostPosted: 01:34 - 16 Feb 2006    Post subject: Reply with quote
Good point. Here is a supplier of them.
lilredmachine
PostPosted: 12:39 - 16 Feb 2006    Post subject: Reply with quote
They have to be setup right. This particular system is bullshit, This system here:
https://www.runryder.com/helicopter/gallery/24172/truck_inside.jpg
Is not. (note also the nitrous injection) Snowmobile 2 stroke motors have been turboed for ages, with a 150% increase in power.
There is no reason 'supercharging' should not work as a principle on 2 strokes. A 2 stroke diesel can be supercharged, and supercharging can work on a 2 stroke with a suitably back pressure adjusting exhaust and a one way valve on the inlet. It's just not practical and quadruples the fuel consumption, looking at 10MPG for a decent 2 smoke.
PostPosted: 12:57 - 16 Feb 2006    Post subject: Reply with quote
Trouble with forced induction on a 2 stroke is that you loose massive amounts of power that you would gain from conventional 2 stroke tuning. Loads of extra complexity and weight for no real advantages that cannot be gained another simpler way.
lilredmachine
PostPosted: 13:02 - 16 Feb 2006    Post subject: Reply with quote
Yeah, that is an issue, also an avenue for 4t that is pretty much closed off to 2t.
PostPosted: 13:06 - 16 Feb 2006    Post subject: Reply with quote
Not really closed off, just that a 2 stroke can be tuned to the same level without needing the complexity.
Only way 4 strokes are going to catch up much more on power is by having the engines have a shorter engine life (already happening, with the new Aprilia V twin having a similar piston life expectancy of an RS125).
The last post was made 20 years, 126 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.87 Sec - Server Load: 1.61 - MySQL Queries: 13 - Page Size: 119.79 Kb
