honda vfr400 nc21 dead battery
badboy1974
PostPosted: 20:36 - 15 Feb 2006    Post subject: honda vfr400 nc21 dead battery Reply with quote
hi guys,
i am in urgent need of advice, i have replaced my regulator rectifier with a secondhand part, but the battery is still going flat...the guy i bought the bike from says he replaced the battery any ideas...anyone?? :( :(
pirate
PostPosted: 23:00 - 15 Feb 2006    Post subject: Reply with quote
I think your best bet is to buy a new regulator rectifier .
Had the same problem with an nc30 it cost 120 euro for the regulator rectifier or drop it into ur local dealer,they find the prob quick enough and wont cost a lot for them to check
www.125power.com
PostPosted: 01:18 - 16 Feb 2006    Post subject: Reply with quote
Run a voltage meter across the battery terminal with the battery fully charged and fitted to bike. Starting bike should see the volts dip then rise again and maybe rise to 1-2 volts more than battery with engine dead, revving the bike up should see an increase in volts too also you will probs notice the headlight brightens as you rev bike, if this is not happening buy a new regulator or have old one tested
My eBay Items
badboy1974
PostPosted: 17:54 - 16 Feb 2006    Post subject: Reply with quote
cheers guys ill take your comments under advisement..
Very Happy
does anyone have workshop manual in pdf format for nc21??
sickpup
Old Timer
PostPosted: 18:04 - 16 Feb 2006    Post subject: Reply with quote
First job load test the battery but unless you have a load tester you won't be able to. They coast about £45 from machine mart.
Start your bike with the lights off and connect a multimeter set to DC across the battery. You should get a reading of around 14.2 volts at idle rising to around 14.9v max when reving.
Try the same with the lights on and tell us your reading.
Next dissconnect the generator and start the bike. The generator should have 3 yellow wires coming out of it. Now connect a multimeter set to AC to two of the wires in turn so you do a total of 3 tests. Rev the bike and you should get a reading of around 50-60Volts.
If on any test you don't get a decent reading theres your problem.
badboy1974
PostPosted: 22:15 - 19 Feb 2006    Post subject: Reply with quote
thanks again guys...have tested voltage from battery, and from alternator...the reading from the alt was less than shit...so i have got one coming, will relace and re-check voltage output..
cheers again Laughing
The last post was made 20 years, 173 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 2.37 - MySQL Queries: 13 - Page Size: 47.48 Kb
