Mr Valve, meet Mrs Piston. Oh dear...
Korn
Admin
PostPosted: 02:19 - 22 Feb 2006    Post subject: Mr Valve, meet Mrs Piston. Oh dear... Reply with quote
I finally got around to pulling the R6 apart today, to examine the damage from its little incident at Brands. It's major carnage in there... Sad
[ Click for big pictures ]
Hmm, I think we've found the problem:
https://www.kornel.com/pics/r6/tP1010020.jpg
Broken valve (top right) and the two others it took with it:
https://www.kornel.com/pics/r6/tP1010021.jpg
Valve stem punched a hole in the piston, lots of shrapnel and damaged barrel:
https://www.kornel.com/pics/r6/tP1010022.jpg
Remains of cam follower and valve shim:
https://www.kornel.com/pics/r6/tP1010028.jpg
Very mashed spark plug:
https://www.kornel.com/pics/r6/tP1010033.jpg
Damage to cam lobes:
https://www.kornel.com/pics/r6/tP1010037.jpg
Well and truly bolloxed:
https://www.kornel.com/pics/r6/tP1010043.jpg
3516 Miles, 11 Countries
phantomtek
Lil Joe Tek
PostPosted: 02:26 - 22 Feb 2006    Post subject: Reply with quote
Check the Haynes - Those valves look a touch warped.
Reevo8
PostPosted: 02:44 - 22 Feb 2006    Post subject: Reply with quote
Looks good to me! Mr. Green
05 ZX10R, (**05 WKR) Very Happy
Shaun
Likes 'em bent
PostPosted: 08:15 - 22 Feb 2006    Post subject: Reply with quote
Shocked
That looks really quite expensive!
Zimbo
PostPosted: 08:48 - 22 Feb 2006    Post subject: Reply with quote
Ouch!
How did that manage to happen?
PostPosted: 09:24 - 22 Feb 2006    Post subject: Re: Mr Valve, meet Mrs Piston. Oh dear... Reply with quote
Oops.
I do have an r6 engine for breaking, though Smile.
byke95
PostPosted: 09:40 - 22 Feb 2006    Post subject: Reply with quote
Can that even be fixed or are you looking at needing a new engine?
PostPosted: 09:57 - 22 Feb 2006    Post subject: Reply with quote
Ouch. Suspect that the head could be repaired but will be cheaper to source a 2nd hand one.
Cannot see clearly enough in the picture if there is any damage to the bore, but with luck you can get away with just a piston there (and cleaning out the engine thoroughly).
PostPosted: 14:03 - 22 Feb 2006    Post subject: Reply with quote
The same thing happened to my TT600, only worse.
Engines are cheap for R6's on ebay and the like. They aren't cheap for TT600s! Smile
Fahd
PostPosted: 21:38 - 22 Feb 2006    Post subject: Reply with quote
Ouch! it looks like that is going to hurt your wallet! Laughing
Deano
PostPosted: 12:55 - 26 Feb 2006    Post subject: Reply with quote
that may of been due to the fact of the valve clearances bein checked for a while could of been way out.
the constant slammin of the valve against the port which would of made it snap causing that mess.
The last post was made 20 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 68.71 Kb
