simple SQL query is giving me a headache! (help ;) )
feef
Energiser Bunny
PostPosted: 16:00 - 23 Feb 2006    Post subject: simple SQL query is giving me a headache! (help ;) ) Reply with quote
this shoud be simple, but my brain's hurting.
I have a table with 3 fields...
IDnum,content,application
eg
123,stop,fb
123,start,fb
123,continue,fb
123,fault,fb
123,start,gt
123,stop,gt
123,continue,gt
123,start,ha
321,stop,fb
321,start,fb
321,continue,fb
321,fault,fb
321,start,gt
I need to know All those unique IDs that have "start" against them, but have not got "stop" against them, I'm not interested in the other content strings.
I need to query it based on a specific application ID.
there will be many records from each IDnum, but only one start for each. I need to know all those IDnums that have "started" and not "stopped"
this is on SQL Server.
tia
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
veeeffarr
PostPosted: 16:05 - 23 Feb 2006    Post subject: Reply with quote
Is IDNum Primary?
That list is an example of the values in your table?
So basically you want to know how many have started?
PostPosted: 16:06 - 23 Feb 2006    Post subject: Reply with quote
select distinct idnum
from blah
where content = "start"
and idnum not in (select idnum from blah where content = "stop")
Quick and nasty way of getting a list.
feef
Energiser Bunny
PostPosted: 16:09 - 23 Feb 2006    Post subject: Reply with quote
Toby R wrote:
Is IDNum Primary?
how can idnum be primary with multiple duplicate entries Wink ? :p
a
feef
Energiser Bunny
PostPosted: 16:12 - 23 Feb 2006    Post subject: Reply with quote
from blah
I'd rather avoid a sub-select in a table this size...
in this case a subselect is nasty, but not quick Wink
a
veeeffarr
Sorry mate,
I didn't read properly, Keith's should work.
PostPosted: 16:18 - 23 Feb 2006    Post subject: Reply with quote
Not sure if you could play around with a left outer join, joining the table to itself on the idnum with one having start, the other stop, and then ignore the ones where it does find a match.
Failing that you could make the subselect more specific.
PostPosted: 16:23 - 23 Feb 2006    Post subject: Reply with quote
Not tried this, but something like it might work (too many versions of SQL, think this works in some but not something I have used)
select *
from (select a.idnum subIdnum, a.content subContentA, b.content subContentB
from blah a left outer join blah b
on a.idnum = b.idnum
where a.content = "start"
and b.content = "stopped")
where subContentB is null
feef
Energiser Bunny
PostPosted: 16:28 - 23 Feb 2006    Post subject: Reply with quote
that's when my head started hurting Wink
a
PostPosted: 16:31 - 23 Feb 2006    Post subject: Reply with quote
Try the example. Be interested to know if it works (suspect it would in Oracle).
veeeffarr
PostPosted: 16:32 - 23 Feb 2006    Post subject: Reply with quote
I'd use the subselect unless speed really is an issue.
Unless you really want to be arsed with joins Smile
feef
Energiser Bunny
PostPosted: 16:47 - 23 Feb 2006    Post subject: Reply with quote
speed is in issue when the last subselect query I ran took a day and a half to run.
Very Happy
I think i've solved it tho, having found from the developer that there is another check I can do on the preceding data to narrow down the search further...
I'll go kick his ass later.
a
PostPosted: 16:48 - 23 Feb 2006    Post subject: Reply with quote
Have you tried the join example?
Just interested in whether it would work.
feef
Energiser Bunny
PostPosted: 17:08 - 23 Feb 2006    Post subject: Reply with quote
the bit...
works.. but you can't select from a select like you can in oracle.
at least it doesn't work in it's current guise.
Still.. by giving me botht he start and stop messages, that actually gives me more info.. it also shows that there have been multiple start messages sent in some case.. providing us with some useful info we hadn't thought about
thnks
a
PostPosted: 17:27 - 23 Feb 2006    Post subject: Reply with quote
Interesting, something Oracle manages to do!
If the SQL is needed for a program then at least it is useable.
feef
Energiser Bunny
PostPosted: 17:47 - 23 Feb 2006    Post subject: Reply with quote
it's a one off request for stats info..
thanks
a
The last post was made 20 years, 195 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 101.03 Kb
