Jacking up the bike
curryfishball
PostPosted: 12:05 - 25 Feb 2006    Post subject: Jacking up the bike Reply with quote
Hi, I need to jack up the front of my bike to take off the front wheel. Where are the points where I can put a jack under? Will the exhaust hold up or the oil sump bit? Thanks
Kram
PostPosted: 13:03 - 25 Feb 2006    Post subject: Reply with quote
what bike is it?
the exhaust might(if it's a 4cylinder, but it's iffy) easier to take the exhaust off, and stick a car jack on the oil sump (with a block of wood or something in the way).
but make sure your car jack won't go down Evil or Very Mad by itself
FS1E -> SR125 -> CB400N -> CB650 -> FZR600 Genises -> VFR400 NC21 -> CBR900RR Fireblade -> Renault Clio 1.4
curryfishball
PostPosted: 13:14 - 25 Feb 2006    Post subject: Reply with quote
its a gixer6. ohh, taking off the exhaust would take ages. i think
Kram
PostPosted: 13:16 - 25 Feb 2006    Post subject: Reply with quote
if the bottoms of the 4 downpipes are level, you should be able to get away with a block of wood under all four (to equal out the weight) and car jack (or 2) under the wood. (use a rear paddock too)
might work ok (are the downpipes rusty?)
curryfishball
PostPosted: 13:21 - 25 Feb 2006    Post subject: Reply with quote
thx. the pipes are not rusty. i'll take a look later to see if they are level.
Guest
PostPosted: 15:01 - 25 Feb 2006    Post subject: Reply with quote
A piece of wood between the jack and the pipes or sump works for me
https://img.photobucket.com/albums/v471/fastfitter/DSCF0053.jpg
ancientd
PostPosted: 15:07 - 25 Feb 2006    Post subject: Reply with quote
Unless you've got one of those central stands that takes the majority of the bikes weight, then it's not wise to jack up the bike by the exhaust. The best way is to lift up the front with an engine hoist and rope or strap around the steering head.
I ride 3 bikes, a Thundercat, an FZRexup 1000 Streetfighter and a Jawa 350 Combo, something for all seasons.
NC30UK
PostPosted: 15:11 - 25 Feb 2006    Post subject: Reply with quote
I find putting it on the side stand then jacking it up from underneath a good way of doing it. it's alot more stable than you might think
loply
PostPosted: 16:15 - 25 Feb 2006    Post subject: Reply with quote
Ive you have an abba stand then just put a heavy weight on the back of the bike, and it will naturally lift the front up.
Yamaha SZR660 Caution to the wind, the throttle pinned!
Nath
PostPosted: 17:07 - 25 Feb 2006    Post subject: Reply with quote
I certainly wouldn't put anything under the exhaust pipes. I stick a few breese blocks under the sump with a bit of wood on top. Get them under by pivoting the bike on center stand.
Hard livin', hard luck.
PostPosted: 17:33 - 25 Feb 2006    Post subject: Reply with quote
If you push the bike over towards the sidestand from the front, the wheel will come up off the ground. You can usually then prop a bit of wood or an axle stand under the engine or frame to hold it there.
curryfishball
PostPosted: 22:26 - 27 Feb 2006    Post subject: Reply with quote
thx guys. i took a look at the underside and the exhaust and sump were pretty much even, so got a jack and a block of wood and spread out the weight.
The last post was made 20 years, 174 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 73.04 Kb
