DVD-Rs
Rookie
PostPosted: 22:32 - 26 Feb 2006    Post subject: DVD-Rs Reply with quote
I bought these off eBay, as they were the cheapest around, basically!
I have a problem though. I try to burn stuff (either data or DVD video) from my laptop but they won't work! It gets 1% into organising stuff before burning, and then just sits there making a noise in the drive. I know the drive works, as I burnt a VCD to check this and it worked, plus I bought some Maxell from Virgin and they worked fine.
These DVDs burn fine in my standalone DVD recorder from TV, but they just don't want to work in the laptop drive.
Did I buythe wrong kind? Can anyone help me out?
daz|n00by
The Internet
PostPosted: 23:16 - 26 Feb 2006    Post subject: Reply with quote
Just sounds like a dodgy batch m8,
i get loads of duff burns from the same pack that works fine, i just throw them in the bin.
Also is your burner compatable with dvd- disc's?
"Its Better To Burn Out Than Fade Away!!!!!!" "Lifes a bitch and then you Die"
"I`m a tool, one with just enough intelligence to know it, just enough spirit to resent it...but not enough backbone to do anything about it. " Siggi 2006 pure class. Smile
Rookie
PostPosted: 23:48 - 26 Feb 2006    Post subject: Reply with quote
As I say, they still work in my DVD recorder, surely this means they should work OK as discs?
The burner suppsoedly records DVD+, DVD- and DVD RAM. I'm no expert, I assume these are either + or -?
Skunkcap Freddie
PostPosted: 10:55 - 27 Feb 2006    Post subject: Reply with quote
TDK(GOOD), Verbatim(GOOD), Datawrite(SKETCHY), Bulkpaq(CHEAP TURD), Memorex(TURD), Hyundai(TURD)
try burning at a lower speed mate. laptop drivers are picky for burning disks. you generally need to use good disks to burn at full speed. using likes of ritek, certain tdk disks,tayiouden disks are pretty good aswell.
or go to https://forum.rpc1.org/dl_all.php and try updating your firmware
fuzz
PostPosted: 12:49 - 27 Feb 2006    Post subject: Reply with quote
What make is the DVD writer? If you look up the drive model on the manufacturers website it should give you a list of tested discs and the speeds the drive can write to them.
The last post was made 20 years, 191 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 43.64 Kb
