Hmm, plastic screws and their faults
Adam_P
PostPosted: 12:30 - 27 Feb 2006    Post subject: Hmm, plastic screws and their faults Reply with quote
The screen on the Fazer is held in place with five plastic/nylon screws (four across the top, two either side near the mirror stalks) and one under the front beneath the lights.
So, I was giving the bike a bit of a clean the other day and took the screen off to clean behind it and clean around the back of the clocks.
Started to refit the screen and went to tighten one of the left hand screws up and...
the head sheard off, leaving the threaded section deep within the confines of the bike! And no, before you ask, I wasn't screwing it too tight, I was going round them all making sure they were just tight enough. I reckon it was because it was bloody freezing in the garage and they were probably all a bit brittle. Still a pain in the arse though!
I know its not a big deal and hardly merits a spot on the workshop section, but I was just wondering whether any of you had had the same problem before and had any advice on the best way of attempting to getting it out?
Thanks
Adam
Colin McRae MBE 1968 - 2007 RIP Sad
Orwell Rolls in his Grave
God is imaginary
EuropeanNC30R...
Gay Hairdresser
PostPosted: 12:52 - 27 Feb 2006    Post subject: Reply with quote
The plastic screws were a god-send after the metal rivets that originally held my bikes screen in place. Had to drill about 8 of those out.
PostPosted: 12:53 - 27 Feb 2006    Post subject: Reply with quote
I would just drill it out. Should be very easy to drill the soft plastic. Then replace then with decent stainless bolts.
Adam_P
PostPosted: 13:54 - 27 Feb 2006    Post subject: Reply with quote
Thanks Keith.
I had thought about replacing them with metal ones when I first saw they were plastic after I go tthe bike. I had visions of rounded of heads and non-tightening screws after a few cleaning session.
Then I went and broke one instead! Rolling Eyes Laughing
I take I should just be using a drill slightly smaller than the screw and take it slowly until it all just comes out around the bit? I've never had to do it before.
Its also handy that I noticed my Grandad left me his brand spanking drill that I found in amongst a load of his old stuff in the garage the other day too! Laughing Exclamation
God is imaginary
PostPosted: 14:39 - 27 Feb 2006    Post subject: Reply with quote
I suspect that if you are careful drilling the you will probably get away with a tiny hole down the middle of the remains of the plastic, and with the remains of the thread undoing as you drill.
Only thing to be very careful about (not so much here, but with metal fairing bolts) is that the fastener can easily get hot enough to melt the fairings when you drill them out.
finpos
PostPosted: 14:44 - 27 Feb 2006    Post subject: Reply with quote
Rather than have a go with a drill, I'd be tempted to stab it with a screwdriver you've heated up with a blowtorch or on a hob. Obviously, don't use gramps' bestest screwdriver for the job Smile
Push the screwdiver in a could couple of mm whilst hot and then hold it while it cools. It should then be pretty firmly attached to the stump which will unscrew easily.
If you choose metal to replace the errant bolt with, make sure you use a thickish plastic washer between the head of the bolt and the screen, otherwise the screen might crack - they use plastic there for a reason Smile.
finpos.
ZRX61
Victor Meldrew
PostPosted: 15:50 - 27 Feb 2006    Post subject: Reply with quote
What he said....
numark1
Scared of girls
PostPosted: 18:51 - 27 Feb 2006    Post subject: Reply with quote
You can buy replacement screen screws from most bike shops for about £5. Thumbs Up
Jrod
Page 3 Girl
PostPosted: 19:33 - 27 Feb 2006    Post subject: Reply with quote
Purple oens at that!
ZRX61
Victor Meldrew
PostPosted: 02:58 - 28 Feb 2006    Post subject: Reply with quote
Or you can use plastic number plate screws from Halfords for about 10p each..
The last post was made 20 years, 174 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 66.68 Kb
