twistgrip and throttle cable
billy_other
PostPosted: 21:20 - 27 Feb 2006    Post subject: twistgrip and throttle cable Reply with quote
Hello folks,
Having a problem with the twistgrip/throttle cable. I've had the twistgrip, inner slidder ( correct term?) replaced and the throttle cable cleaned etc, but still the twistgrip /throttle sticks i.e wont return if you let it go. I even tried putting some grease in the housing, no luck!
How do you adjust the throttle cable and make the twistgrip return properly etc? Is there a beginners guide somewhere i can read or buy etc?
Hope this makes sense
Thanks for your help
Bill
Guest
PostPosted: 21:46 - 27 Feb 2006    Post subject: Reply with quote
If the bar isn't bent, try just loosening the screws off a little and wiggling stuff around then re-tightening.
It is possible to trap the throttle grip in the housing, there's a 'sticky-up bit' that the cable slots into and this can foul the body of the switch housing if they're not lined up properly before tightening the screws (I'm assuming a standard Jap type throttle/switch assembly here)
JMH
PostPosted: 08:53 - 28 Feb 2006    Post subject: Reply with quote
Not sure what kind of carb(s) you've got, but you may want to check the spring return on the carb to make sure it's not misaligned or stuck. It sounds like the the cable itself is not pulling the throttle sleeve back to it's resting position.
Make sure the throttle assembly is lined up straight with the handlebar, too! Hope this helps!
--JMH
billy_other
PostPosted: 22:35 - 28 Feb 2006    Post subject: Reply with quote
Thanks Guest and JMH for the advice
Cheers
Bill
The last post was made 20 years, 168 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.62 - MySQL Queries: 13 - Page Size: 38.77 Kb
