Linux on PowerPC
iCraig
PostPosted: 23:01 - 27 Feb 2006    Post subject: Linux on PowerPC Reply with quote
Right, I currently have several Mac's I currently use.
One of which is a Power Macintosh 7200/90, and its currently running Mac OS 8.6 and being used as a Web/File Server, which is good and stable but getting long in the tooth and nothing supports it anymore after all it was released in 1999.
So I am wondering if anyone on here has ever installed Linux onto a PowerPC machine. Or if they know of any Linux distro that can be installed onto an OldWorld Mac with a Graphical install with a lowish amount of memory? Something like the equivilent of Vector Linux on the x86 platform?
Specs of the Machine are as follows: 90Mhz PowerPC 601 CPU, 64Mb FPRAM, 10Gb SCSI HD, ATi Rage Pro 16Mb GFX Card.
Ta
Craig
Nath
PostPosted: 04:26 - 28 Feb 2006    Post subject: Reply with quote
Debian works on most Power PC systems. https://www.debian.org/ports/powerpc/
Assuming that port uses the standard installer, then it is not really "graphical". It is a menu based system, which is fairly easy to follow and *reasonably* self explanatory. It's not a case of sitting back and watching the installer do its thing, but you shouldn't find it too difficult as long as you know at least a little about your system.
Debian can be installed off a downloaded cdrom, or off the net (think you need to make a boot floppy to get the installer started).
On a system like yours, Debian really is your best option. You could try one of the more newbie-friendly distros, but I think you will find them too bloated for your low-spec hardware.
If you want a GUI, don't even think about using the KDE or Gnome desktops, as they are bloatware crap that will never work on an old box - For a lightweight GUI I advise you try the Blackbox WM (which you will be able to install easily with Debian). I run Blackbox on an old 50mhz Sun Sparcstation and have no complaints.
Hard livin', hard luck.
NSR Mick
PostPosted: 10:20 - 28 Feb 2006    Post subject: Reply with quote
I think Yellow Dog does PPC's
The last post was made 20 years, 188 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 36.55 Kb
