Ohlins Ride Height Adjuster
craigs23
Mr Muscle
PostPosted: 23:25 - 27 Feb 2006    Post subject: Ohlins Ride Height Adjuster Reply with quote
Just a quickie - is it recomended to support the bike so it's off its rear suspension to adjust rideheight (it's a nut/lock nut setup) or can I do it with the bike in situe?
Ichy
PostPosted: 23:41 - 27 Feb 2006    Post subject: Reply with quote
Either on or off the ground, but it might be easier with some weight off the back wheel.
I think that the only problem with the ohlins is when you try to measure sag, the spring affects negative sag which means you should remove it from the bike. Always happy to be corrected.
craigs23
Mr Muscle
PostPosted: 23:51 - 27 Feb 2006    Post subject: Reply with quote
The sag's already been setup by Kais (to my bodyweight). The bike sits a little too upright for my liking when on the sidestand, thought I'd give it a couple of mm more ride height - it's a lot lower than standard atm (the front even more so).
Ichy
PostPosted: 11:21 - 28 Feb 2006    Post subject: Reply with quote
Your probably already aware but just in case, remember lifting the back will affect the steering. As the front been lowered through the headstock?
craigs23
Mr Muscle
PostPosted: 21:41 - 28 Feb 2006    Post subject: Reply with quote
Nope, front has been lowered due to Ohlins fork springs.
The last post was made 20 years, 168 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.27 - MySQL Queries: 13 - Page Size: 43.04 Kb
