BRAKES !!!
 Topic moved: from General Bike Chat to The Workshop by G (27 Feb 2006 - 23:27)
camcam
PostPosted: 00:13 - 28 Feb 2006    Post subject: BRAKES !!! Reply with quote
slight prob with brakes first the brake light would go off when using the back brake unless i put my foot under it and lifted now after some tinkering i need to push fairly hard to get it to come on and i got a peice eft over and not sure where it goes....
thanks
laugh now cry later
SUZUKI GSXR600 98 SRAD RED/BLACK ***sold gonna miss you***
SUZUKI GSXR750 '00 K1 SHAPE BLUE/WHITE
Jammy-R6
PostPosted: 00:21 - 28 Feb 2006    Post subject: Reply with quote
Isn't that the return spring for the brake pedal? Else you have to rely on the retraction of the pots to push the pedal back!
moonym20
PostPosted: 00:35 - 28 Feb 2006    Post subject: Reply with quote
if its on an NSR it is the Rear Brake Lever Return Spring Smile should be the same with any other bike...
also the microswitch for your rear brake light is either faulty or simply needs readjusting.. it could possibly have come out of its holding clip. If you have a good look at the microswitch (assuming its an NSR) you will see where it should fix, and also a head you can get pliers around to switch the 'biting point' for the light
with the rear break lever there should be two tiny holes around the midpoint of the lever... put one end of the spring in there, and then on the foot peg bracket you should find another hole.... pop it in there and voilla
Hope it Helps Thumbs Up Karma
A scientist crossed a skunk with an owl. He's got a bird that smells but doesn't give a hoot Smile
ZZR-Souls
PostPosted: 00:42 - 28 Feb 2006    Post subject: Reply with quote
I reckon that's a brake pedal spring off a GSXR 600 Srad. Rolling Eyes Rolling Eyes
Check out the innards if the brake light switch. They are prone to filling up with water and going rusty inside. Give it a clean and apply some copper grease to the sliding parts. Oh yes and put the spring back on the pedal.
JOIN IN THE BIGGEST RIDE-OUT OF 2007 here
Jrod
Page 3 Girl
PostPosted: 12:58 - 28 Feb 2006    Post subject: Reply with quote
If I had my bike I'd come fix it for you. If you wanna bring it round mine sometime I will sort it.
camcam
PostPosted: 16:45 - 28 Feb 2006    Post subject: Reply with quote
what gave that away i wonder Rolling Eyes
all sorted now thanks for the help karma will be given out Thumbs Up Thumbs Up
laugh now cry later
The last post was made 20 years, 171 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.51 - MySQL Queries: 16 - Page Size: 50.44 Kb
