Effects of running on a worn out chain
loply
PostPosted: 21:49 - 28 Feb 2006    Post subject: Effects of running on a worn out chain Reply with quote
Hi folks,
My chain and sprockets could do with replacing; They're not in desperate condition, but I'm aware that they're on my todo list.
Problem is, im eternally skint so anything not strictly essential goes straight to the bottom of the priority list.
What are the effects of having a slightly worn C+S? Will it affect the transmission or shifting by any real margin, or is it purely a matter of "it might snap"?
Cheers,
Rich
Yamaha SZR660 Caution to the wind, the throttle pinned!
Teaman
PostPosted: 21:58 - 28 Feb 2006    Post subject: Reply with quote
yes they might snap but they will effect handling of the bike, not sure on a degree as it depends on how the bike is being ridden and everything else,
it will effect economy for the same reason,
your better off buying a new chain and sprockets, even if there cheep, they will keep you going untill you get better ones
There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them.
instigator
PostPosted: 22:00 - 28 Feb 2006    Post subject: Reply with quote
Erm, yes it might snap and take off your lower leg if that is not an important enough reason to replace it then I really question your sanity.
Having had 2 chains snap on me, it is not something I will ever neglect again.
If it's worn, you'll keep having to adjust it and adjust it and perhaps get to a point where it can't be adjusted anymore. Any we all know how chains can jump off sprockets (see bazza's thread)
PostPosted: 22:05 - 28 Feb 2006    Post subject: Reply with quote
If it is badly worn, I would replace it. You are riding a 660cc single, it WILL snap it, they are very hard on chains.
I did exactly the same as you on my MZ (which had the same engine), thought 'Oh, chain's a bit rattly but I've had them worse, I'll replace it after the summer run.'. Four days later it snapped.
Keen
plus if the chain comes off the front sprocket its gonna make a nasty mess of your soft engine. That'll cost alot more than new C+S. I'd bite the bullet and get a new set Thumbs Up
0ddball
PostPosted: 22:08 - 28 Feb 2006    Post subject: Reply with quote
My 'effect' is a crashed bike stuck in the garden waiting to be rebuilt after the chain snapped and got jammed.
ZRX61
Victor Meldrew
PostPosted: 22:15 - 28 Feb 2006    Post subject: Re: Effects of running on a worn out chain Reply with quote
loply wrote:
strictly essential
The C&S should be on that list you muppet. Rolling Eyes
bazza
PostPosted: 14:04 - 01 Mar 2006    Post subject: Re: Effects of running on a worn out chain Reply with quote
The chain and sprocket is essential. Possible consequences:
1. Snapped chain causing physical injury/involuntary lower limb amputation.
2. Snapped chain bunching on the front sprocket causing internal gear/clutch/engine damage.
3. Chain jumps off rear sprocket away from wheel causing internal damage as above. (Also known as "doing a bazza").
4. Chain jumping off rear sprocket towards wheel causing locked rear wheel, loss of control, high likelihood of injury/death if it occurs at speed.
There are other scenarios, but you get the picture. The point is, all of them will end up costing you a hell of a lot more than replacing your C+S, so the "eternally skint" excuse is really just bullshit.
Stop pissing about and get it sorted.
doggone
PostPosted: 14:11 - 01 Mar 2006    Post subject: Reply with quote
Usually once you become aware they are rattling they get worse very rapidly.
As peeps are saying, let it break and it will most likely cause more damage and expensive repairs.
iCraig
PostPosted: 14:18 - 01 Mar 2006    Post subject: Reply with quote
Riding a bike on a worn chain & sprockets will drastically affect your fuel consumption too.
Mine did on the CB450, was getting 50 miles to £5 with the old C&S, now it does about 80-90 miles to £5. So it probably would cost you more if you left it a while even if it didn't snap.
Cognitive_Faux
PostPosted: 14:43 - 01 Mar 2006    Post subject: Reply with quote
its just dangerous.
only need a few teeth on 1 of the sprockets to go while riding, and your gona be off, on your arse.
you could just take the sprockets off and turn 'em round if your that skint. or not ride it.
if the chain snaps, it could fuck you up, or just the front sprocket cover.
if you dont sort it now, it will get MORE expensive later. or hurt you.
bike theory (pass) bike test (pass)(4 minors) car theory (pass) car test (pass)(1 minor!!!)
cb125t->sr125->expressII50->xlr125->GS550L & GS550E->XBR500 'chop'->YZF600R->FZS600->GSF650->fantic 212cc->gsf650->kwak GT750->VFR750 ->
HGV class 2 (pass)
Jack_Cheese
PostPosted: 14:55 - 01 Mar 2006    Post subject: Reply with quote
i'm in the same boat. sprockets are ok, the chain has quite a lot of sideways play in it though. A new renthal C+S kit is £90, and i need a new pair of tyres, front pads, new handlebars and to get my test booked.
My nexy month's wages are booked Thumbs Down
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
loply
PostPosted: 21:20 - 01 Mar 2006    Post subject: Reply with quote
Its not like the chain is about to snap, I just said it was pretty worn... I bet 30% of this forum is riding on a chain in the same nick as mine.
Thanks for pointing out the fuel consumption issue, though that's rarely a problem for me.
0ni
PostPosted: 23:05 - 01 Mar 2006    Post subject: Reply with quote
My old chain and sprockets were on there very last limb when I went to replace them. I do look after my chain - keep it lubed and tightened - however the mileage I had been doing really took its toll on the C&S.
Jerky response to opening up the throttle. No smoothness in crusining along - I was sure I was having fueling/spark issues until I changed the C&S. Almost every little rattle and bump went away.
I have had a chain snap and rap itself around the chain adjuster and locking the rear wheel. Happened at 60 - stayed on - just.
Its a lovely day, just wait until some bastard spoils it.
SoND
PostPosted: 23:15 - 01 Mar 2006    Post subject: Reply with quote
On worn C&S you will lose loads of power to the back wheel.
My set was destroyed and when I replaced them it felt like a whole new bike.
extreme3d
PostPosted: 00:14 - 02 Mar 2006    Post subject: Reply with quote
instigator wrote:
Erm, yes it might snap and take off your lower leg.
Now Greggy, I know the Scott's have a fetish with kilt wearers swinging large heavy war axes severing people's limbs but do you have to make it so blunt... Laughing
Seriously though Loply if you are in any doubt take it to a garage and get them to advise you on how long it's got left. As a general rule of thumb though, adjust to the right tension and then pull the rear most links on the rear sprocket. (half way up). If you can pull them back more than 2mm then there is too much wear on the teeth.
bish777
PostPosted: 02:25 - 02 Mar 2006    Post subject: Reply with quote
Its a serious safety issue as discussed. Also a worn chain and sprocks can wear the output shaft bearing on your motor which is a real pain. A seriosly shagged chain can also eat the chainguard and damage your swingarm.
If your poor, buy heavy duty NON O-ring chain and slap that on there till you can afford flash chain
X-ring chain + sprocks on my GSXR1100 is 110 quids worth.
Non O ring standard H-duty chain and sprocks can be had for 40 quid for mine. Wont last as long but safer all round
GSXR1100J
dodsi
Dirty Carny
PostPosted: 02:51 - 02 Mar 2006    Post subject: Reply with quote
Rich mate, its not worth risking, I had to replace mine in the passed. Couldnt afford too being a student and all but HAD too.
Thumbs Down
You could do more damage than snapping a chain.
If you order from B&C express I think I can supply you with a chain splitting tool so you can do it yourself. Thumbs Up
The View Askew
PostPosted: 03:48 - 02 Mar 2006    Post subject: Reply with quote
A stitch in time saves nine Thumbs Up
Black Knight
PostPosted: 12:25 - 02 Mar 2006    Post subject: Reply with quote
Hello bud,
If you can't afford to change it now, fair enough, but make sure your prioties are right. I know far too many people that will go out on the piss but can't afford to pay the rent - not saying thats the case with you, just a general observation.
I'd say if the chain does need replacing I would advise not riding the bike, especially heeding Stinkwheel's advice above.
If you do NEED to ride the bike, get some good cleaner, some quality oil and give it the best service of its life, check every link for tight spots and try and work them out.
If you have to keep it a while, keep it in the best condition possible.
Oh - and of course, riding very very smoothly.
Where does a turn end? 'Where you can do anything with the gas you want to, where you are brave again, where your attention is free from the turn, where you are sure you can do it better next time; that's the end' - Keith Code.
HurtMePlease This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
loply
PostPosted: 18:02 - 04 Mar 2006    Post subject: Reply with quote
Bleh, I'll put £15 a week away and change it ASAP... It pulls back from the rear sprocket a fair bit more than 2mm and it moves from side to side a bit.
The chain itself, being Scottoiled all its life, almost looks brand new, but is obviouslly "neatly worn" if you know what I mean.
Thanks for the advice folks, helpful Thumbs Up Karma
Thanks for the offer of the splitter dodsi, I'll let you know when I order it what kind it is.
anders This post is not being displayed because the poster is banned. Unhide this post / all posts.
bish777
PostPosted: 18:45 - 04 Mar 2006    Post subject: Reply with quote
standard non O ring chain is so cheap, that you really have no excuse not to at least change to one of these.
Its a misconception that Oring chain is stronger, its just more resistant to road crap.
GSXR1100J
loply
PostPosted: 19:01 - 04 Mar 2006    Post subject: Reply with quote
Also need sprockets though.
The last post was made 20 years, 210 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.20 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 129.42 Kb
