| spike240 |
 spike240 L Plate Warrior
| spike240 |
 Posted: 22:46 - 28 Feb 2006 Post subject: |
It isn't all that great but if you click the button marked "www" under this post it should take you there.
Actually, I had best have a look myself, haven't checked it is working for ages (did I mention it is a bit shoddy? )
I presume you were looking for the bit on soldering? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| spike240 |
 Posted: 23:45 - 28 Feb 2006 Post subject: |
A 20 or 30 amp fuse should be easily enough (think the heated grips only pull about 3~4 amps). For a cheap relay just go to a car scrappy.
Best place to wire then into I have heard is the feed for the rear brake light switch. Means that if you make a real mess of the wiring then you can just buy a new switch (a lot of rear switches include an inch or 2 or wiring). Use this as a trigger for the relay with a main feed frpom the battery.
| spike240 |
 Posted: 12:44 - 01 Mar 2006 Post subject: |
No problem. You would probably get away with one relay, I would use a single-throw, twin terminal five pin relay. This has two seperate outputs, you could use one for the socket and one for the grips.
Most of them are designed to cope with 30amps, if you are drawing more than that it is too much anyway. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 20 years, 166 days ago. Instead of replying here, would creating a new thread be more useful? |
