| Marcg868 |
 Marcg868 World Chat Champion
 Posted: 17:07 - 09 Mar 2006 Post subject: Mouth Ulcers! |
Basically ive got two massive ones on top left side and bottom right, both near the really pointy looking vampire tooth! And just want to know, ive tried everything for getting rid and they havent started to heal or anything. Tried bonjella, listirine mouth wash gets rid of the white stuff n then they bleed a bit, but they're just so painful, can hardly eat without my eyes watering.  ____________________ JACK, MISS YOU LOADS YOU LEGEND. |
| veeeffarr |
 veeeffarr Super Spammer
| veeeffarr |
| flat spot |
 flat spot World Chat Champion
 Posted: 17:22 - 09 Mar 2006 Post subject: |
You're just overtired. Probably coming down with a cold or something. "Adcortyl" is the stuff you want for your ulcers. Put it on at night and things will be noticeably better in the morning.  |
| JonB |
 JonB Afraid of Mileage
| Annabella |
 Annabella Like a person, only smaller
 Posted: 17:33 - 09 Mar 2006 Post subject: |
If they are larger, or a similar size to the nail of your little finger then you should go to the doctors.
Mouth Ulcers that don't clear up and/or are large are usually a result of something else being wrong with you. It may just be that you are generally run down or tired, but it is possible that there is something more seriously wrong - ie. some kind of infection.
Are you feeling well in every other way? ____________________ Avast! Pirates ahoy!
I did Cadwell!
www.bikepics.com/members/bella |
| colin1 |
 colin1 Captain Safety
| Handsome |
 Handsome World Chat Champion
| Katie |
 Katie Spanner Monkey
 Posted: 21:51 - 09 Mar 2006 Post subject: |
Wet you finger, dip it in salt, put it straight on the ulcer. That bad boy will sort it right out, but will probably make you cry. So .. the question is, how much of a man are you?
That's what I do anyway, dries it up and goes in about a day. ____________________ Never have a row with an Idiot, they drag you down to their level then beat you with experience. |
| nrml76 |
 nrml76 Brolly Dolly
| Annabella |
| Katie |
 Posted: 12:30 - 10 Mar 2006 Post subject: |
It does! The trick is to dance around the kitchen going "Ohh ow, ow ow oohh ahh ow." while it stings. That's what I do.  ____________________ Never have a row with an Idiot, they drag you down to their level then beat you with experience. |
| Marcg868 |
| Kwaks |
 Kwaks I'm not a fast rider
 Posted: 13:01 - 11 Mar 2006 Post subject: |
Sounds like this is a recurring problem, as Annabell said see your quack,this can be a sign of something else,eg the stomach bug could still be there and causing problems in your whole digestive system. Also mention it to your dentist,he will check out the proximity of your canines to the ulcers to see if they are causing it. It may be that they are a bit sharp and rubbing on your gums,especially if you have an overbite.
Could simply be the helmet pushing your gums into the teeth at these points  |
| hellkat |
 hellkat Super Spammer
 Posted: 01:58 - 12 Mar 2006 Post subject: |
And no unprotected oral sex with attractive strangers till they've healed up  ____________________ Not nearly as interesting in real life. |
| Marcg868 |
| hellkat |
 Posted: 17:38 - 12 Mar 2006 Post subject: |
If you're always getting them, you should perhaps look at your nutrition.
I notice when I am not eating enough fruit or vegetables that the sides of my mouth get cracked, like cold sores but not. It's often a sign that you're run down. Once I start eating proper food with proper vegetables etc., instead of just pot noodles/pasta/rice/cornflakes/toast in the middle of the night then it clears up and goes away.
The "vampire"/fang teeth are described as "canines" by dentists (for fairly obvious reasons, I would have thought). ____________________ Not nearly as interesting in real life. |
| MarkyPancake |
 MarkyPancake Crazy Courier
 Posted: 22:38 - 12 Mar 2006 Post subject: |
Bonjela works for me when I get them.  |
| The Tot |
 The Tot World Chat Champion
| Marcg868 |
 Posted: 01:05 - 13 Mar 2006 Post subject: |
Banana's work a treat, they usually help them clear up quicker. I have a thing for them, eat about 4/5 a day tried the gum shield thing titz its not pleasant but it works and my god ive never had my eyes water so much but they're clearing up which is a good thing. ____________________ JACK, MISS YOU LOADS YOU LEGEND. |
| Simple |
 Simple World Chat Champion
 Posted: 13:06 - 16 Mar 2006 Post subject: |
mouth ulcers can be caused by infection, there are over 10 000 000 bacteria in your mouth, most of those are there purely to out compete pathogens (unfeindly bacteria) which you come into contact with, what starts off as a little ulcer could become larger due to these pathogens getting into the ulcer which is the same as a cut in your skin, if you are run down/tired/stressed or recovering from illness you are more at risk of ulcers, and the larger ones.
if the ulcer is particularily bad/large may be worth going to docs, though taking anti biotics for a mouth ulcer is not to be advised.
I put tooth paste on them, hurts like hell but I like the tast of bonjela and find my self inadvertently licking it off  ____________________ Insta - FemFeral |
| Marcg868 |
 Posted: 18:39 - 16 Mar 2006 Post subject: |
I love Bonjela too, Aniseed Mmmmmmmmmmmmm, bit like Ouzo in a tube Got some Pastey stuff from my Dentist plus a scrape and polish of me teeth £25  ____________________ JACK, MISS YOU LOADS YOU LEGEND. |
| Simple |
 Posted: 18:42 - 16 Mar 2006 Post subject: |
Ahh the joys of being a full time student
Had my check up yesterday, had an exray, and that was it. all is well.
so to date I have no fillings, cavities or anyother nasties.
The x-ray showed that I have no lower Wisdom teeth, Result!
That's evolution for ya!  ____________________ Insta - FemFeral |
| Marcg868 |
 Posted: 01:17 - 17 Mar 2006 Post subject: |
Jammy gett! wish i was still in full time education, My Mrs is and she loves to gloat at me Ah well, my Wisdom teeth are all through, and ulcers are healing nicely, just need balance my diest more and sleep better. ____________________ JACK, MISS YOU LOADS YOU LEGEND. |
| Dragonfly |
 Dragonfly Super Spammer
The last post was made 20 years, 141 days ago. Instead of replying here, would creating a new thread be more useful? |
