PC Problem - powering off
Bike Chat Forums Index -> The Geek Zone Goto page Previous  1, 2
wher2guv
PostPosted: 19:09 - 10 Mar 2006    Post subject: Reply with quote
You should try a new fan on the psu have you noticed it getting louder I have had three or four where the fan started to give up it still spins but at a slower rpm.
Replacing them sorted everyone also ad a system fan if the computer is in a warm room
Silver
PostPosted: 00:16 - 14 Mar 2006    Post subject: Reply with quote
Memtest was fine.
Been running the PC with the case wide open and exposed to better air circulation for the last few days. Haven't been arsed to get some new thermal paste as yet, but it seems to have cured the problem. Interesting that all the heat readings are fine (bad connection probably), and it has only gone like this recently though, with no changes.
Cheers for the ideas guys.
McJamweasel
BCF Junkie
PostPosted: 20:28 - 14 Mar 2006    Post subject: Reply with quote
Are your fans/heatsinks clogged with dust?
When I was working at OSUK we had one system come back for repair becuase it kept shutting down, like yours is. There was literally half an inch of dust on every fan and heatsink and another half inch all over every horizontal surface! Madness.
Silver
PostPosted: 20:45 - 14 Mar 2006    Post subject: Reply with quote
Nah, it's not that bad!
colin1
Captain Safety
PostPosted: 03:43 - 15 Mar 2006    Post subject: Reply with quote
i had this problem and so did distortion i think.
mine is an amd and after i changed the way the power leads inside were connected it was ok
there were basically two leads from the power supply, one had several devices connected to it and one was just connected to the hard drive
i switched the leads around so that the graphics card got its own lead (high load) and the lower consumption ones went off the other lead
i also disconnected the dvd drive and the floppy drive and just kept the dvd burner connected to use as a dvd drive
i cant remember if i changed the mother board power lead around or not
i havnt had any problems since
i think distortion had his power supply replaced with an uprated one but i dont know how that went
mine probably is caked in dust as i have never cleaned the dust off but as long as it works i dont care
daz|n00by
The Internet
PostPosted: 13:00 - 15 Mar 2006    Post subject: Reply with quote
Sorry Collin but i,m not sure what kind of power supply unit your using but i would get yourself a new one m8.
Never seen a psu with just a single connection out of a psu, they are usualy equal and have at least 2 connections on each.
Graphics cards only use high load under gaming etc ,when not being used for extreme work they dont use more power.
So your psu came with more than 1 motherboard plug?
did you make this psu?
Neutral
"Its Better To Burn Out Than Fade Away!!!!!!" "Lifes a bitch and then you Die"
"I`m a tool, one with just enough intelligence to know it, just enough spirit to resent it...but not enough backbone to do anything about it. " Siggi 2006 pure class. Smile
craigie b
Citizen Smith
PostPosted: 13:11 - 15 Mar 2006    Post subject: Reply with quote
leave the case open and run it for a few days. I had a similar problem and it seemed to be heat related.
The last post was made 20 years, 172 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 2
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 53.16 Kb
