Hacking challenges/Encryption query
fuzz
PostPosted: 18:06 - 14 Mar 2006    Post subject: Hacking challenges/Encryption query Reply with quote
I've been working through the challenges set on https://www.hack4u.org and have come across one that uses MD5 encryption. Now I've decoded the MD5, but I can't figure out why you can't decode the hash using the same method to encode. All of the MD5 encoders say "You cannot decode MD5." I have found a way around it, but I was wondering why you would have a 'secure' algorithm that cannot be reversed. Surely you need to decode it to understand it, otherwise what's the point?
FreshAL
Sir Crashalot
PostPosted: 18:35 - 14 Mar 2006    Post subject: Reply with quote
MD5 is a hashing algorithm for validating passwords etc.
EG:
Server stores MD5 encrypted password hash
User submits password plain text, which is hashed (encrypted) via MD5
Server compares hashes - if they match, password was correct.
veeeffarr
PostPosted: 18:37 - 14 Mar 2006    Post subject: Reply with quote
MD5 is also used on files to verify theyre not corrupt or missing data.
carvell
Scuttler
PostPosted: 18:46 - 14 Mar 2006    Post subject: Re: Hacking challenges/Encryption query Reply with quote
I'll try and explain.
Firstly, it's not encryption, it's a hash. BCF uses it infact, to store your passwords.
When you sign up, a MD5 hash is generated, which is unique to any possible password, this MD5 hash is then stored in a database. When you want to log in, it gets the MD5 hash of the password you have typed, if this matches the stored hash it lets you in, if it doesn't it doesn't.
You see, there's no way you would ever need to decode it. There's no way Korn could know our passwords, they are all stored as a MD5 hash and all it does when you try to log in is compare these.
An example of a very simple hash is to say add all the numbers up. Say your password was "1234", then the hash might be 10. If you password was "5632" then the hash might be 16. These hashes are what is stored in the database.
If I said to you "the hash is 16", would you be able to tell me my 4 digit code? Of course you wouldn't - there's no way you can know exactly what I've typed in. As a test, the hash for the hashing algorithm I've decribed above is 12, I'll leave it to you to tell me my 4 digit pin. MD5 is a hell of a lot harder than that.
You haven't cracked MD5, you haven't. There's no way you can do it apart from brute force which takes weeks and years on very fast computers.
Yamaha TDM 850
fuzz
PostPosted: 00:04 - 15 Mar 2006    Post subject: Reply with quote
Right, I understand why you wouldn't need to decrypt it if it compares hashes for verification, but I disagree with the fact that it is un crackable.
For instance:
With three different websites that offer MD5 encryption, the string bcf became 28cb510090e7e926daa92745a8b02362. Another website offered decryption of the hash and returned the original string, bcf.
Also, isn't there something referred to as collision, which occurs when two different strings return the same hash?
carvell
Scuttler
PostPosted: 01:40 - 15 Mar 2006    Post subject: Reply with quote
URL?
This website will use a brute force attack on the algorithm, it's not decrypting it, it's trying every single possibility until it gets the right one. Maybe it can decrypt basic 3 letter strings, I don't know. Try this:
baaf3f4f6c53fa5c961382b395b03b50
I'll give you a thousand pounds if you can tell me what the original string was to create that.
Yes - but as far as I know no such strings have been found yet. If they are found then they'll be so obscure then it wouldn't matter anyway.
Yamaha TDM 850
fuzz
PostPosted: 10:12 - 15 Mar 2006    Post subject: Reply with quote
No I can't crack that. I believe these websites work by storing a database of hashes generated using the algorithm. You enter the hash, it checks the database, and returns the original string that created it. So it is like brute force, only it stores every hash it creates so that it does not need to crack it every time. Complex/long strings might be secure, but simple/short strings can be found using this method. That's a lesson to everyone then - dont use dictionary words for your password!
Suzuki
Roger
PostPosted: 10:59 - 15 Mar 2006    Post subject: Reply with quote
If you do want to use some secure encryption, but want to be able to decrypt it at some point, you should look into a RSA and its equivalents.
They use a public and private key pair to secure the data.
Everybody creates a keypair. You give out the public key, and keep the private key to yourself.
I want to sent a message to Fuzz, so I encrypt it using his public key. The only way to read that message is to decrypt it using his private key. So only Fuzz can read it.
Conversley, Fuzz wants to send a message and prove that it was him that sent it, and that the message hasn't been tampered with.
So, he writes his message, and then creates a *HASH* of his message. This hash is then encrypted using Fuzz's PRIVATE key. Now, anybody who reads the message can confirm that it's genuinely from Fuzz, and that the message contents hasn't been altered.
They decrypt the hash using Fuzz's PUBLIC key, and then compare the decrypted hash to their own generated hash of the message itself. If they match, the message is untouched and definitely from Fuzz.
Most email clients will allow you to use this functionality.
Have a look at PGP (or the free version, GPG, which might now be OpenPGP).
Enigmail is a plugin for Thunderbird which will let you encrypt/decrypt messages in this manner. Smile
<Simple> no I'm shaven Jon Razz
<Simple> it is a big enough hole.. I'll leave it now
Ride: 1999 Suzuki GSXR600 (yellow/black) IRC: Stats - Relationship Map
fuzz
PostPosted: 12:24 - 15 Mar 2006    Post subject: Reply with quote
I need some help now finding a password. The only clue I have is that it is weak and 'try the defaults to be on your way.'
I've tried the obvious ones like admin, root, default, password. What other passwords might you get as a default (like on a router or something)?
Suzuki
Roger
PostPosted: 12:32 - 15 Mar 2006    Post subject: Reply with quote
give us the keyword to load your level and i'll have a go at it.
And, since this topic was brought up, here's my public key if you want to send me something encrypted...
Code:
-----BEGIN PGP PUBLIC KEY BLOCK-----
Version: GnuPG v1.4.2 (MingW32)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=Pe+S
-----END PGP PUBLIC KEY BLOCK-----
fuzz
PostPosted: 15:28 - 16 Mar 2006    Post subject: Reply with quote
Am I right in thinking that there are 16^32 possible permutations for the hash? That's 3.4x10^38 or 340 000 decillion. So don't feel too bad Luke, it was less than 10% Shocked
Suzuki
Roger
PostPosted: 15:33 - 16 Mar 2006    Post subject: Reply with quote
10^6 is a lot less than 10% of 3.4*10^38 !!
fuzz
PostPosted: 15:52 - 16 Mar 2006    Post subject: Reply with quote
Yes that's right, but you can't fault me on the logic Wink
I was thinking quickly, decillion milion, 10. It's more in the region of 0.0000000000000000000000000000001%.
It's been a long day............
The last post was made 20 years, 171 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 84.99 Kb
