NSR Lights
JayZ
PostPosted: 21:49 - 02 May 2003    Post subject: NSR Lights Reply with quote
One of my headlight bulbs have gone.
Have a spare for the CBR, will this do, or are they a lower watt bulb?
Also the tail lights have packed up working, had a quick check but it's getting dark any ideas, and yes bulbs are fine. Smile
Thanks.
PostPosted: 21:57 - 02 May 2003    Post subject: Re: NSR Lights Reply with quote
I think the NSR uses 35W.. and higer can drain the battery I believe.
PsychoHippy
Jammy Git
PostPosted: 22:35 - 02 May 2003    Post subject: Reply with quote
If you use higher wattage bulbs then you need to watch out for blowing fuses (put larger ones in), or even burning out the wireing loom! Shocked
I spend all my money on bikes and beer, the rest I simply waste!
fred
Guest
PostPosted: 22:43 - 02 May 2003    Post subject: bulb Reply with quote
std nsr r 25w
bedspeed do a 35w which is max nsr can safely take.
Think cbr bulb is different fitting
JayZ
PostPosted: 11:07 - 03 May 2003    Post subject: Reply with quote
Had a butchers this morning and noticed they are different.
Bit of a pain in the arse to get too. Confused
So you recommend 25/35w's, and they are safe to run?
Keep on hearing about bedspeed, never heard of them, where are they?
fred
Guest
PostPosted: 19:45 - 03 May 2003    Post subject: bilbs Reply with quote
I have used blue 35w from bedspeed.. do search on net... since new. no problems at all.. cost abot £4 each
35w is not too bright but compared to 25w its a searchligt
fred
Guest
Guest
PostPosted: 22:09 - 04 May 2003    Post subject: Reply with quote
hi,
nsr headlight as standard is 25/25w, but you can get, (i did 6 months ago), 35/35w halogens in the bosch honda fitting from a firm called xs parts, e-mail www.xs-parts.co.uk, as im looking at the invoice they cost me, 13.85 inc vat &carriage, so far ive had no problems, and they are much brighter than the standard items. i got the original info from a post from "nsrboi", only seems right to pass a good thing on.
regards
carl
JayZ
PostPosted: 22:58 - 04 May 2003    Post subject: Reply with quote
Cheers chaps.
Picked up 35/35w from my local bike shop, they work a treat. Smile
The last post was made 23 years, 183 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 53.77 Kb
