| DynamiteBoy |
 DynamiteBoy Scooby Slapper
| MikeH |
 MikeH Brolly Dolly
 Posted: 13:05 - 18 Mar 2006 Post subject: |
Prob just needs using, but a full service and fresh fuel won't go amiss.
Mike  ____________________ Busa Junkie |
| DynamiteBoy |
| nrml76 |
 nrml76 Brolly Dolly
| 0ddball |
 0ddball World Chat Champion
| ZRX61 |
 ZRX61 Victor Meldrew
| Teaman |
 Teaman World Chat Champion
 Posted: 19:10 - 18 Mar 2006 Post subject: |
or you could even aim it into the wind to lesten the area of force,,
I stood my bike up on a muddy field on its side stand at the base of snowdon in a gale and thing stayed up,,
surprised me cos about 5 tents didnt
check the shape of the tent,, thats when it was breeezy ____________________ There is no point in ranting about someone stupid because there is nothing u can do about it. There is no cure for stupid.
Someone stupid does not realise they r stupid.stupidity is indistinguishable from malice U just have to accept that some people are thick as p1gsh1t and work around them. |
| Kickstart |
 Kickstart The Oracle
 Posted: 20:05 - 18 Mar 2006 Post subject: |
The GPZ side stand does leave the bike rather too vertical. You get used to parking it with care.
To be honest with the problem pulling away I would tend to think it is something to do with not being used for ages. Drain the carbs and the fuel tank and clean the rubbish out (Charlottes GPZ500 is a pig for getting water in the fuel tank).
| RiChY_RiCh |
 RiChY_RiCh L Plate Warrior
| iCraig |
 iCraig World Chat Champion
| DynamiteBoy |
| stinkwheel |
 Posted: 17:10 - 20 Mar 2006 Post subject: |
Kangarooing sounds like either a fuel starvation issue, water in the tank or an electrical problem.
Since the fuel tank was full of crap, this would be favourite, could have bunged something up in the carbs.
I would make sure the tank is cleaned out and give the fuel filter a clean. You might get away with running some redex through it although if something is realy blocked, it probably wont do much.
Also worth checking the air filter is clean.
If this doesn't work, I would be thinking about giving the carbs a strip and clean because at the revs you describe the problem is probably either in the pilot jet or one of the small venturi jets that are located round the edge of the air inlet.
The most difficult bit of pulling the carbs is getting the airbox rubbers back on afterwards. Also worth having a couple of clamps handy to clamp off the anti-icing hoses, then you don't have to drain down all the coolant. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| DynamiteBoy |
| Kickstart |
 Posted: 18:17 - 20 Mar 2006 Post subject: |
Before diving in and stripping the carbs, drain them. On the bottom of each float bowl you will see a small cross head screw. Undo this and the float bowl will empty out. Do this to both carbs, wash away what is spilt and then try the bike (note it will take a while cranking over to start, as it needs to refill the carbs and the GPZ does not have a "prime" position on the fuel tap).
| stinkwheel |
 Posted: 20:43 - 20 Mar 2006 Post subject: |
I would just use the bog standard oil and change it every 3,000miles without fail. I do a filter with every oil change (manual recommends every second one), I reckon your fiver would be better spent on a filter for every change rather than some fancy oil.
The engine design is over 20 years old, any oil you can buy today will exceed the specification it was designed for. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| RiChY_RiCh |
| DynamiteBoy |
 Posted: 08:14 - 23 Mar 2006 Post subject: |
Cheers for all the suggestions so far....a mechanical minded bike friend came over last night and helped me strip/inspect/clean and re-build the carbs on my GPZ500.... wasnt much dirt in the carbs but the bike now starts and sounds so much nicer...
Unfortunately the first gear problem is still happening....had the bike up on the centre stand with rear wheel off floor, but unless the engine was revving over 5k the engine would stall.... . My friend is adement that the problem is electrical and has taken my haynes manual home to inspect, but i was wandering if anyone on BCF had any ideas as to what could cause this.
Heres the symptoms in more detail:
- Idles in netural fine, clutch in first fine, let out clutch engine cuts out as if 'turning off at key'
- Unable to engage second gear unless back wheel spinning
- rear wheel seems a bit hesitant to start spinning (stiff), i but it down to being stood so long
- had heated grips added by previous owners just before sale
As menthoned previously when shes moving shes fine, its getting her there... cars at lights must think im a nutter as i rev the bollocks off her and shoot off..... .
Cheers for all your help so far...Ow ____________________ "I dont like my Job anymore - I dont think i'll go" OfficeSpace
Honda CG125 (sold) - Kawasaki GPZ500s (sold) - Kawasaki Zephyr 550 (sold) - Kawasaki er6n (current work horse) |
| finpos |
 finpos World Chat Champion
| DynamiteBoy |
| finpos |
 Posted: 11:04 - 23 Mar 2006 Post subject: |
I'm actually thinking maybe that the final drive drag is what is causing the stalling. You need more power/revs just to overcome that drag (it would be like doing a hill start on very steep hill).
The good news is that if this is indeed the problem, your bike will go even faster when it's fixed
Other than that I agree with your mate - loss of power under load can usually be put down to an electrical problem - but more likely a marginal component (e.g. coil, ht lead...) than a switch.
On an old bike that has been stood, it may well be a combination of both. Whatever the case, get that final drive sorted.
finpos. |
| DynamiteBoy |
| Kickstart |
| finpos |
| stinkwheel |
| DynamiteBoy |
 Posted: 19:11 - 23 Mar 2006 Post subject: |
Just thought i'd post to let u all now that the bike is now running fine...eliminated the problem this evening.
After all the hassel the side-stand switch was to blame, one of the terminals was loose with the switch covered in s**t... . Managed to get her out on the road briefly where she ran fine through all speeds and gears...
Have a busy weekend ahead of me - change oil/ remove and inspect back drum (stiff)/ oil chain and general wash.
Cheers again for everyones help and suggestions...Ow ____________________ "I dont like my Job anymore - I dont think i'll go" OfficeSpace
The last post was made 19 years, 287 days ago. Instead of replying here, would creating a new thread be more useful? |
